GD: 02-08 Nylatron Shifter Cable Bushings by TurboS13Hatch
Old Mar 24, 2009 | 12:55 PM
  #81
TurboS13Hatch's Avatar
I am currently out of stock.. I'll let you know when I get more in.
Thanks..
Travis
Old Mar 26, 2009 | 12:58 PM
  #82
TallTom's Avatar
Thanks..
Travis
Any loose ETA? Like within 2 weeks? Just curious.
Old Mar 26, 2009 | 09:38 PM
  #83
MAYBE tomorrow.. I am waiting on another batch from the machine shop. I'll keep you guys updated.
Old Mar 28, 2009 | 05:14 AM
  #84
SteveB123's Avatar
Old Mar 29, 2009 | 10:59 AM
  #85
Steve.. you weren't trying to put the metal sleeve inside the new bushing were you? They don't need a sleeve.. The material is self lubricating, and has a longer wear life than steel.
Maybe I misinterpreted what you were saying.. let me know..
Thanks for the feedback!
Travis
Old Mar 29, 2009 | 12:34 PM
  #86
SteveB123's Avatar
Old Mar 29, 2009 | 01:05 PM
  #87
PulsarGTS's Avatar
Originally Posted by SteveB123
The select cable end fastener has to fit inside the bushing....my car can't be the only one like this, can it?
The only thing you have to do is remove the stock bushings from both ends of the cable toss them and replace them with the hard bushings and reattach. You only need use two of the 3 bushings sent, since you have a 5.5gen. one has a larger hole than the other two. DONT use it.
Old Mar 29, 2009 | 01:29 PM
  #88
SteveB123's Avatar
Old Mar 29, 2009 | 01:41 PM
  #89
PulsarGTS's Avatar
So...everyone with a 5.5gen pays for and receives an extra bushing, that they don't need?
I didn't notice that in the original post.
I used all the bushings I paid for.
Hmm, maybe I didnt knw where to install the last one??? lol I didnt see a place for it. Uh oh. I just remember him saying he needed to knw the years of the cars and I assumed that since the ES kit used two bushings, that we only needed two for this. Well I'll wait for Travis to clear it up. Good thing I kept it.
Old Mar 29, 2009 | 02:41 PM
  #90
SteveB123's Avatar
Old Mar 29, 2009 | 04:29 PM
  #91
PulsarGTS's Avatar
There are three rubber cable end bushings in the stock cable shifter assembly.
I'm assuming you didn't replace the select cable end in the engine compartment.
I replaced the one on top of the tranny and the one on the top right side of the shifter. What was the third one? I saw a bushing on the lower left side of the shifter but it looked like it was riveted on. I'm gonna go look at it again in a sec. I think you are right about using all three. I installed the rear pair of ES shifter frame bushings that I could find earlier. They do make a diff I was surprised, too bad I lost the rest of them. The inside of my center consul was just nasty tho.
Old Mar 30, 2009 | 04:30 AM
  #92
SteveB123's Avatar
Old Mar 31, 2009 | 04:28 PM
  #93
Nope.. you use all three..
Two go into the trans compartment, and are the same size.. One that is the same diameter, but has a smaller hole in the center, goes inside the vehicle, on the shifter side of the cable.
Travis
Old Mar 31, 2009 | 06:10 PM
  #94
PulsarGTS's Avatar
Travis
Hmm, I swear my car didnt have a bushing on the one of the cables on the tranny that looked like it could be taken off. Well I give it a look tom.
Old Apr 1, 2009 | 09:29 AM
  #95
SteveB123's Avatar
Old Apr 1, 2009 | 12:35 PM
  #96
Hmm.
I've got two that fit well in on the tranny end of things, and one that has a larger ID, that fits a bit loose on the shifter side. I plan to bush it up slightly myself.
Is it loose on the post itself.. or is it just loose from side to side? You will have some side to side play.. that's normal.
Travis
Old Apr 1, 2009 | 06:24 PM
  #97
SteveB123's Avatar
Old Apr 2, 2009 | 05:01 AM
  #98
That's odd.. You should have 2 posts on the transmission side that are the same size, and one inside the car that's just a hair larger.. which is why I sent one bushing with a slightly larger hole.
Travis
Old Apr 2, 2009 | 07:59 AM
  #99
Ok guys.. I've got about 20 sets of these in stock, and ready to ship.
Let me know..
Travis
Old Apr 2, 2009 | 09:21 AM
  #100
TallTom's Avatar
Let me know..
Travis
I'm in. Where do I send the paypal and how much?
'02 Maxima.
Old Apr 2, 2009 | 11:39 AM
  #101
Hey..
The info is listed in the first post..
Travis
Old Apr 2, 2009 | 12:17 PM
  #102
TallTom's Avatar
Hey..
Travis
Doh! Money is sent.
OK, for the record, I think three bushings are sent in the kit:
  • 2 identical ones which go under the airbox for the linkage.
  • 1 that is slightly larger which goes to the linkage at the shifter.
Correct? If so, seems pretty straight forward to me.
Old Apr 2, 2009 | 12:19 PM
  #103
That is correct.. as long as it's for a 02/03.. If it's for a 04+, then, your kit will come with 2 bushings that are the same, and one that is larger in diameter. The 04+ has a larger bushing on the trans side, and the lower trans bushing/shifter bushing will be the same ID and OD.
It's pretty self explanatory when you pull the old ones out..
Travis
Old Apr 2, 2009 | 03:28 PM
  #104
SteveB123's Avatar
Old Apr 3, 2009 | 07:59 AM
  #105
True.
But it completely ignores the fastener on the "select" cable, which fits INSIDE the stock bushing, shrinking its ID.
How were we to deal with that?
You completely lost me on this one... Would you mind snapping a pic to show me what you're trying to explain?
Travis
Old Apr 3, 2009 | 01:03 PM
  #106
SteveB123's Avatar
Old Apr 4, 2009 | 12:26 AM
  #107
No disrespect intended at all when I say this.. but, I have NO idea what you're trying to explain.. lol..
There's 3 bushings, which go inside of metal rings/loops.. two on the trans side, and one in the car, on the shifter. The 4th cable end (inside the car), which has a plastic fitting on it, is left alone..
Here's a good pic of the in-cab single bushing, installed.. It also shows the plastic cable end, which is left alone..
This pic shows the lower trans bushing installed..
And the upper..
Can you show me from those pics, what you're trying to describe? I don't understand what you mean by "hard plastic fastener".. The OEM bushings are just rubber, with a brass sleeve on the inside. Again, not insulting you here.. I honestly don't understand what you mean, and I'd like to help you get this straightened out!
Travis
Old Apr 4, 2009 | 12:33 AM
  #108
Here's a set of pics, showing the two different sets of bushings.. These are from the Spec V, so don't pay attention to the year breakdown in the pics..
Aftermarket at the top, and OEM bushings below
These are what you should have in a 02/03 Max..
All the same OD, but, one bushing (which goes inside the car), has a slightly larger ID
These would be for the 04+ guys..
Two with the same OD, and ID, and one with a larger OD, but, the same ID. One of the smaller bushings goes in the cab, and the larger and remaining small bushing go on the trans side.
Do you have something different? Once you remove the factory bushings, shown at the bottom of each pic, the new ones should slide right in.
Travis
Old Apr 4, 2009 | 01:19 PM
  #109
SteveB123's Avatar
Old Apr 5, 2009 | 08:06 PM
  #110
Really?? Would you mind snapping a pic of this, and posting it up for me? I've never ran into what you're explaining before.. I'd like to make changes if necessary.
What's the production date on your Max?
Thanks!
Travis
Old Apr 6, 2009 | 08:52 AM
  #111
TallTom's Avatar
Hey, I was curious to see if the busings are being shipped out this week. I have time this weekend (which is rare) and would love to install them.
Old Apr 6, 2009 | 09:07 AM
  #112
Yes.. the ones that were paid for recently will go out this week..
Old Apr 6, 2009 | 11:05 AM
  #113
TallTom's Avatar
Sweet. Thanks.
Old Apr 14, 2009 | 12:00 PM
  #114
TallTom's Avatar
So were the bushings shipped out?
Old Apr 19, 2009 | 09:32 PM
  #115
Yes sir.. all bushings that were paid for (as of 4/18), were shipped out on Friday.
You should all have received tracking info via email, and you should have them in 3-4 business days.
Thanks!
Travis
Old Apr 19, 2009 | 09:33 PM
  #116
Steve.. Did you ever get a chance to snap a pic of that peice that you were talking about? I see that you edited your comments.. Did you get it figured out? Just wanted to make sure you were taken care of. Let me know..
Travis
Old Apr 20, 2009 | 07:21 PM
  #117
SteveB123's Avatar
Travis
Removed and sold them.
Lesson learned.
Old Apr 21, 2009 | 11:06 AM
  #118
Lesson learned.
I don't understand.. What lesson did you learn? Everyone else who has these, never had any problem whatsoever with the install or otherwise. I bent over backwards to try and help you figure this out. You never gave me pics, or details.. I even followed up to make sure that you had gotten this figured out. Why the animosity? You never gave me a chance to help you figure this out.
Travis
Old Apr 27, 2009 | 06:13 AM
  #119
TallTom's Avatar
I was able to install the bushings yesterday along with the TWM Performance STS adapter and have good news and bad news:
The good news is that most of the bushings installed without an issue and the feel of them plus the STS makes a huge improvement over stock. It's a shame the car couldn't come this way from the factory.
Now for the bad news. the bushing used for the lower endlink is not the same as pictured in the pics. They must have changed the design. First, it isn't attached with a cotter pin. It's attached with a wire style C clip which was awkward to remove especially since I didn't have a small mirror to see how it went on. I was able to remove the clip, slide off the endlink and remove the OEM bushing. Here is where the problem lies.
The bushing has a sleeve with a special end that is used to attach the C clip. I slid on your new bushing by itself and it was way too short in width. I'm sure I cold have ghetto fabbed some washers and a way to attach the C clip but would be concerned with it falling off when I'm out on the road.
I took the factory bushing off the sleeve to see how big the opening is. The largest drill bit I own is a 3/8" and the sleeve has a small bit of play on it. I took pics to try to show the differences.
The OEM bushing on the left is for the upper endlink. The bushing on the right has the sleeve/adapter above it.
With everything I experienced, there should be no reason to touch the lower bushing because replacing it only has a minimal improvement with too much work and the possibility of totaling the wired C clip that is quite hard to access and reattach from above. Just looking at the bushing shows that there isn't much rubber to cause sloppiness for the inside diameter is bigger but the outside diameter is the same. Technically, you could attempt to bore out the new bushing to a larger diameter to fit over the OEM sleeve, but I'm not sure how much improvement you could feel.
Old May 13, 2009 | 09:05 AM
  #120
dutch078's Avatar
keep it metal
pm sent
