***Luxer LED universal lights, best/brightest around!***
Old Mar 22, 2010 | 12:14 PM
  #81
jsmithsole's Avatar
*moderator*
Originally Posted by maxprivate
Bump for pics in a 4th gen. I need to install one of these 9 led kit in my truck but it looks like one of the adaptors that come with the 9 LED kit needs to be used to plug into the type of existing connector in the car. I cut off my existing bulb housing that was in my trunk (wanted to go with something brighter), so I only have the neg and pos wires. Can I cut off the harness plug on the 9 led kit and wire in into my neg and pos wires? Is it the 9 led kit polarity sensitive?
You can do that and they are but won;t burn if you go the wrong way on the first try! I have these in my trunk and wired them the same way but wired to extra bulbs in as well. It works fine! Let me know, if you need 1 light it will be $30 + $7,95 shipping = $37.95.
Old Mar 22, 2010 | 06:14 PM
  #82
maxprivate's Avatar
Black Lion
So you used two 9 led kits in the trunk? Can you send me a pic of how much these light up your trunk? Im looking on getting 3 of the 9 led kits. I plan on installing two under the front driver and passenger area and 1 in the trunk. If one isn't bright enough then I'll need two for the trunk. Where did you get grab power for the two 9 led kits in the front of your car?
Old Mar 30, 2010 | 12:15 PM
  #83
jsmithsole's Avatar
*moderator*
Actually I have 3 in there. It's bright, one was OK but I added one on each side as well. As for the floor lights, the 6th gen has them stock so it's just plug and play. But you can either tap into the BCM under the dash or splice into the domes or doors...
My trunk, not the best pic as you can't really see the side lights, but you can see how bright the center one is...
Old Jun 29, 2010 | 12:18 PM
  #84
jsmithsole's Avatar
*moderator*
Summer bump! More products coming soon!!!!
Old Jul 15, 2010 | 11:49 AM
  #85
aoe2champ's Avatar
Hi,
Do you know if it's possible to get green led H3s for my fogs?
~ Thanks
Old Jul 16, 2010 | 12:36 PM
  #86
jsmithsole's Avatar
*moderator*
Anything is possible but i don't sell them. You'd be better off going HID though at this point. The LED H3's I have seen (that are affordable) are junk.
Old Aug 3, 2010 | 01:29 AM
  #87
livindominicano's Avatar
Do you still have them becuase im interested in getting 3 x 9 LED. Two of them blue so i can put in the driver side and passenger side floor and one for my trunk.
Old Aug 4, 2010 | 02:49 PM
  #88
so im guessing the deal is off then?
Old Aug 8, 2010 | 04:36 PM
  #89
Dirtee Max's Avatar
Im interested as well ... de donde eres dominicano?
Old Aug 21, 2010 | 04:46 PM
  #90
jsmithsole's Avatar
*moderator*
Hey livindominicano, post pics if you want once you get them installed!!!
Old Aug 30, 2010 | 10:29 PM
  #91
xProdiigY's Avatar
I have seen these exact same ones on ebay for $0.99......
Old Aug 31, 2010 | 09:38 AM
  #92
jsmithsole's Avatar
*moderator*
Let's see a link, guaranteed they are not the same. But thanks for sharing...
Old Sep 6, 2010 | 02:55 PM
  #93
MoeBelikeMax's Avatar
do those 194's fit in 5th gen license plate
Old Sep 9, 2010 | 07:00 AM
  #94
vastmax's Avatar
Is this still on? my 8 LED lisence plate boards just decided to stop working. Is it $30 shipped for the 194's?
Old Sep 17, 2010 | 02:26 PM
  #95
jsmithsole's Avatar
*moderator*
You require a 168 but the base on the 194 bulb is the same and these are bright as .... , they should fit fine.
Old Sep 17, 2010 | 02:27 PM
  #96
jsmithsole's Avatar
*moderator*
Still on. PM sent.
Old Sep 27, 2010 | 09:25 AM
  #97
NeeDog20's Avatar
Has anyone gotten a complete 4th gen kit?
Probably consist of Map light, Front Doors, Dome, Glove Box, Trunk, and Reverse lights
(Unless people are putting them in their front corner and bumper lights, and taillights as well)...
Old Sep 27, 2010 | 10:12 AM
  #98
sumxsix's Avatar
i want a pair for my 03 maximas head lights parking the ones in the corner which do you reccomemmed and i want em bright white
Old Sep 28, 2010 | 12:32 PM
  #99
1998MaximaGLE's Avatar
I have a 98 Maxima with Gold LEather Interior. I am curious as to how it would look in mine.
Would these LED's burn the plastic covering?
I do not know my buld sizes, can you make suggestions?
I want to replace all the lights Except for the dash(dont want to mess with that)
Old Sep 28, 2010 | 12:33 PM
  #100
I am looking to see how these look in a 4th gen as well. All I am seeing is 6th gens with them
Old Sep 29, 2010 | 05:18 PM
  #101
jsmithsole's Avatar
*moderator*
I don't believe I have sold a full set for 4th gen but,
For the Map light, Front Doors, Dome, Glove Box, Trunk you would need 6 of the 9 LED's.
As for the front corners, you could use the 194's and taillights I suppose you mean the rear sidemarker which you could use the 194 as well. And not sure what the bumper lights are? But you could do the plate lights as well with a set of 194's...
Let me know,
Jason
Old Sep 29, 2010 | 05:20 PM
  #102
jsmithsole's Avatar
*moderator*
You'd want a pair of 194's, I assume you are talking about the front cornering light?
Old Sep 29, 2010 | 05:23 PM
  #103
jsmithsole's Avatar
*moderator*
They will look super bright and good! They will not burn as LED's run cool.
As NeeDog20 said above
Map light, Front Doors, Dome, Glove Box= 4 9 LED's
(I am not too familiar with the 4th gen so double check before you order)
The Sylvania site will have a complete list but the list above should be correct)
Let me know,
J
Old Sep 30, 2010 | 08:38 PM
  #104
rmaxima2010's Avatar
That looks soo cool, I love it
keep it up dude
Old Oct 1, 2010 | 02:17 AM
  #105
Yes they are, time to upgrade!!
Here's pics of our Honda Odyssey:
Check the plate lights, those are the 194's that are $30 a pair.
are these white or blue?
I want this look.
Old Oct 7, 2010 | 09:27 AM
  #106
jsmithsole's Avatar
*moderator*
I want this look.
Sorry for the delay, the two in front are white but the ones right above my camera are blue, might look a bit more blue due to the pic. I'd say based on you wanting this look, go blue but they def are not as bright as white (as far as seeing at night etc...)
Old Oct 28, 2010 | 10:01 AM
  #107
@bighobbz's Avatar
so these lights plug into the place where the factory light goes? i have a 04. any more left?
Old Nov 4, 2010 | 05:06 PM
  #108
xtremepb0's Avatar
do you have any blue dome lights for a 98 maxima?
Old Nov 18, 2010 | 10:32 PM
  #109
jsmithsole's Avatar
*moderator*
Yup still available! There is some back order right now but let me know if you are interested and I will check stock.
Old Nov 18, 2010 | 10:34 PM
  #110
jsmithsole's Avatar
*moderator*
They are all universal plug and play. The 9 led's would work perfectly.
Let me know!
J
(sorry, see above, I went to quote your post and edited it by accident...)
Old Dec 19, 2010 | 09:35 AM
  #111
Kwik33's Avatar
Do you have a web site?
Old Jan 17, 2011 | 01:11 PM
  #112
jsmithsole's Avatar
*moderator*
Sorry for the delay, I do not. I am just a member who is selling these to other members on the site. A friend of mine is the distributor of the lights...
Old Jan 27, 2011 | 02:43 PM
  #113
Street Legal's Avatar
i want a complete set. PM sent
Old Jan 27, 2011 | 07:50 PM
  #114
jsmithsole's Avatar
*moderator*
Thanks! Check your PM!
Old Feb 1, 2011 | 06:57 AM
  #115
replied and sent. decided to go with the blue trunk instead of the white.
Old Feb 9, 2011 | 01:00 PM
  #116
quickhuh's Avatar
Great bulbs, i just did my plate lights and doors with the white. this is the way every car company should make their lights.
Like i told Jason i didnt tell my wife i changed them, she turned the overhead on and yelled she wasnt expecting it to be so bright. then my son (3 years old) said daddy, no yellow, white now
Old May 21, 2011 | 08:03 PM
  #117
MaxPrime's Avatar
Originally Posted by SFSD04SE
Still new to this forum, but what type of bulbs are required for the dome lights in an 04 Maxima SE and the type of bulbs for the floor. I know it's a stupid question, but had to ask. I am really interested in getting these bulbs. I just don't want to buy more bulbs than I need.
I want to to know the same thing i want to make it red all around doors under by your fit both sides and the dome lights not sure yet but i will like to know what i need to ask for or look for and how to install it if is not to much to ask thanks in advance.
P.S is anyone know where to get them please PM anytime thanks.
Old Jun 7, 2011 | 12:06 AM
  #118
ryancustard's Avatar
was it hard to move the stock screen down to the bottom ,,,
Old Aug 7, 2011 | 10:23 AM
  #119
how can i order a pair of 194's for my plates
Old Aug 23, 2011 | 07:19 PM
  #120
stokerdevil666's Avatar
how much for 5 194 blue please shipped to 06450
