Kinetix Racing Intake Manifold - $769.99 Shipped! - Lowest Price Around!
Old Jul 1, 2010 | 08:45 AM
Custom Maxima's Avatar
Temporary Hiatus
...A beautiful price, for a beautiful, hand crafted item.
02-03: Only $769.99 Shipped
04-08 (Includes required EGR Kit): Only $799.99 Shipped
Call us Toll-Free (800) 306-8631 to order! 10-6 EST M-F
Old Jul 1, 2010 | 09:25 AM
Temporary Hiatus
Our long awaited SSV complete manifold solution for the 2002+ 3.5 liter ALTIMA and MAXIMA replaces both upper AND lower factory plenum's. By maximizing plenum efficiency and improving airflow with new intake runner design, the new SSV manifold is a must have performance modification.
Works great in both NA (naturally aspirated) and FI (supercharged or turbocharged) applications. Expect to see a much smoother and stronger power curve, and expect your car to scream past 5500 rpm.
**CLICK ON THE PICTURE FOR DYNO PROVEN RESULTS**
This manifold is constructed entirely of Stainless Steel, then polished out for an absolute beautiful finished product that looks as great as it performs. We chose stainless because of its great thermal properties, conducting 10X!! less heat than aluminum and eliminating much of the manifold's mass, which greatly helps with heat soak. Stainless is considerably more expensive than aluminum, but the finish shines brighter and definitely longer. The overall manifold SAVES 10lbs of weight over stock! Precision TIG welding throughout, and a CNC cut 3/8" main flange. All mandrel bent runners and charge tube, this manifold rivals the quality of manifolds twice its price.
We improved greatly upon the factory plenum designs. The factory manifold uses a variable plenum volume design to lower emissions. The factory manifold design also differentiates runner diameters and lengths to work with this lower emissions feature, at the cost of more horsepower. We developed a straight design, eliminating the variable plenum volume and gearing our manifold for overall performance at all RPMs. We then took each runner and also added velocity stack inlets to each individual runner for even better performance . . . thus the name S.S.V. = Stainless Steel Velocity.
This Manifold is a DIRECT replacement and will work with any aftermarket intake. It can be installed with zero modifications to the car.
We recommend an A/F tuning on Forced Induction vehicles (turbo and supercharged) after installation of the SSV in order to maximize power and overall engine reliability. Tuning is generally not needed in Naturally Aspirated ( NA ) applications.
Each manifold is supplied with all necessary hardware and instructions. There is an additional port supplied which can be used for boost gauges, etc.
vingodine
45
May 21, 2016 12:46 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaxStock
Aug 12, 2015 08:33 AM
Maxboy23
Aug 11, 2015 11:59 AM
