Interior lighting
Old May 9, 2003 | 08:20 AM
GeneK's Avatar
Interior lighting
Do you guys know if dashboard lighting like cruise control switch, gas door open switch, buttons on climate control should light up when parking light/headlights are on? I have ’97 I30t. How can I change bulbs in bottons if they are out?
Old May 10, 2003 | 05:37 PM
Lilswole02's Avatar
check your fuses first
Old May 11, 2003 | 08:57 AM
max5spd's Avatar
Says.."No mo Maximas for me!"
Re: Interior lighting
Are you the same GeneK that used to own a 3rdGen? Several years ago there used to be one on the 3rd Gen BBS.
Sorry for the useless thread
Old May 14, 2003 | 11:13 AM
GeneK's Avatar
To max5spd
Yes it's me. I use to own 3rd gen GXE and I was one of the first memebrs on Andy's Message Board. My car was selected as Best looking Maxima in January, 1999. I'm surprised you remember. I won '97 I30t now.
Old May 14, 2003 | 04:28 PM
max5spd's Avatar
Re: To max5spd
Small world. I used to be AChan on the 3rd Gen BBS. Yeah, Andi's BBS. I remember that. Good to see you again.
Old May 14, 2003 | 04:55 PM
deewanapaki's Avatar
check this site out it shows the process on a 4th gen maxima basically the same thing. i m about to try the same thing on my 99 i30. if you try before me just keep me posted.
http://www.geocities.com/amixam69/nissan/dash/
good luck
Old May 23, 2003 | 03:19 PM
A-RokI30T's Avatar
yes if the parking lights are on then all those lights should be on. you can change those light bulbs easily with stock bulbs or even different color bulbs if you wanted to. you would simply remove the panels on the dash and right behind the buttons is where the bulbs are, remove those and install new ones in. caution though, if you do switch to colored bulbs they might fade over time if you use cheap ones, so i would just stay with stock. hope this helps
Old Oct 25, 2003 | 10:08 AM
pearli30's Avatar
Do you guys know where I can buy a few of these lights, half of my dash (a/c) lights went out, but the LCD is still fine? I took apart the A/C and found the busted lights. Can I get these bulbs at Discount Auto Parts or something like this? Also, what's the model # replacement for these tiny things?
Maximan190
Dec 16, 2015 06:01 AM
sdotcarter
Sep 2, 2015 09:53 PM
A32goldylocks
Sep 2, 2015 06:39 AM
