Need Help!!!!
Old Sep 24, 2003 | 02:02 PM
][ 35's Avatar
Need Help!!!!
Recently, i can hear some flapping noise coming from front end of the car. this flapping sound is only made when i'm driving around 30 to 45ish mph. and i check under the car to see if anything could be flapping to make noise but i'm not able to see anything. any ideas?
Old Sep 24, 2003 | 04:43 PM
MetaOrbit's Avatar
Got Projectors?
There are some underbody kinda plastic diffusers or shields that are held in by a plug or two. I'd look to see if maybe one of your plugs has come out and see if any of those plastic pieces are loose.
Old Sep 24, 2003 | 09:19 PM
][ 35's Avatar
there is 2 plug that is missing... i guess the damn shop lost them when they took it off to install the UDP.... i guess i need to contact the dealer to find out if they sell those plugs...... and hope this will fix it... thanks metaorbit...
Old Sep 24, 2003 | 09:38 PM
MetaOrbit's Avatar
Got Projectors?
Yeah no problem man. Something you might want to try though is zip ties.
I had to remove some of those pieces under the car when I was putting the front lip on mine. As it turned out, I couldn't get the plugs back in, so I just used zip ties to tie all those pieces together tight. It's still holding and it's easy to remove if I need to. You might want to try that first before going to the dealer.
Old Sep 25, 2003 | 05:26 PM
gqmac2's Avatar
Thats really true. All the dealer will do is rip you off. For example, how much is a in cabin filter typically selling for our cars? Well a friendly trip to your local Infiniti Dealer will leave you shelling out $80 bucks for it. Crazy if you ask me.
Old Sep 25, 2003 | 05:27 PM
][ 35's Avatar
cool thanks for the tip... i'll try that this weekend...
