headlight bulbsize?
Old Dec 26, 2003 | 02:32 PM
SuBXeRo's Avatar
headlight bulbsize?
hey guys i wanna chnage the bulb in my headlights to these:
http://www.oznium.com/product_info.p...products_id/57
the bulb are easy to chnage on a 96 i30 right?
and what size should i get
thanx in advance
Old Dec 27, 2003 | 10:11 AM
SuBXeRo's Avatar
doesnt anyone know?
Old Dec 27, 2003 | 11:32 AM
alibaba's Avatar
9004 should be it ... I have a 99 i30 and I use 9004
Old Dec 27, 2003 | 04:06 PM
SuBXeRo's Avatar
ok and the bulbs that i want are 90 watts and in my manual it says 65/45
can it be upped or no cause i dont want to melt anything
Old Dec 27, 2003 | 09:53 PM
I30tMikeD's Avatar
your harness my short out
Old Dec 28, 2003 | 10:27 AM
SuBXeRo's Avatar
might as in etremely good chnace that it will, or might as in theres a small chance. if its a good chance, is there a way to upgarde the wiring harness?
Old Dec 28, 2003 | 11:52 AM
I30tMikeD's Avatar
I can't give you any more info then that. The only thing I know about going to a higher wattage bulb is what maxima owners have posted. I know some have shorted out their harness and some have not.
I went with an H4 harness and bulb when put on my one piece cefiro's, so there is that option.
Old Dec 28, 2003 | 03:20 PM
SuBXeRo's Avatar
well i appreciate allt he info that you have given me. well i am planning on buying the one piece cefiro soon, so i think ill just do what you did. now when i get the h4 harness how do u install it. is there alot of rewiring to do? o yeah and how much for 2 headlights again
Old Jan 1, 2004 | 05:33 PM
SuBXeRo's Avatar
ok i bought my upgrade harness'. now i have a new prob i was specing out what i was gonna have to do, and i need to replace wires to carry the higher wattage. now i looked behind the left side harness and it goes like 4 inches and into a consolodation tube. i dunno where it goes from there. i need to upgrade the wire and i dont know how long it has to be or anything any help on this?
Old Jan 2, 2004 | 10:03 AM
A-RokI30T's Avatar
there's no extra wires that heavy duty harnesses have. which wiring harness did you buy? h4 or 9004? if you're going with the cefiro one piece then it's the h4 harness which has three wires. there's no extra wires on that to figure out where they go. just cut your stock harness and match the proper wires with the harness and the cut wires and u should be all set. with the upgraded heavy duty harness you can use the higher wattage bulbs that u want
Old Jan 4, 2004 | 11:21 AM
SuBXeRo's Avatar
well i got one with 3 wires, and i called my closest infiniti dealer and the guy said i should have rewired sum wires to help with the upped voltage, but i took it to the mechanic and he just patched in the new harness sumthing i could have done. so whatever if it gets fried its his fault and i got normal hl now
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
