Turbo???
Old Apr 6, 2004 | 07:00 PM
CrystalClearI30's Avatar
Turbo???
hey i found this
http://www.importperformanceparts.ne...ec_nissan.html
it says it will work on the cefiro but its unclear of what year and which model it would work on. i know stillen makes a supercharger for my model car but im trying to weed out sum other performance parts and i came accross these would they work on my car?
Old Apr 6, 2004 | 08:58 PM
Karkov's Avatar
Dude i think thats for some old cefiros, i dont know what year they switched things but i would guess it was 3rd gen max's or before. All newer i30s are vq30s or vq35 engines. That would be cool though, its more in my price range.
Old Apr 6, 2004 | 08:59 PM
I30_DRIVER's Avatar
Um you can go to custommaxima.com they sell a turbo kits for a32...
for sure..
but i thing s/c is the better way to go vortech 8 lbs of boost is plenty and no need to lower any compression or wait for that turbo to kick in.
Old Apr 6, 2004 | 09:01 PM
I30_DRIVER's Avatar
and the kit is for the euro model the 2.0 engine v6
dont know if would fit????
Old Apr 6, 2004 | 09:09 PM
I30tMikeD's Avatar
That is not a kit for a 3.0 VQ and the turbo is too small for our engines anyhow.
Old Apr 6, 2004 | 09:15 PM
I30tMikeD's Avatar
for sure..
the only advatange to going with stillen's votech SC is that it is cheaper. A basic used SC set up can be had for $2k. There is no need to lower the compression on a turbo maxima unless you want more than 10lbs of boost. And 10lbs of turbo boost is much more power than 10lbs of SC boost because turbos are much more efficient. As far as waiting for the turbo to spool, that all depends on the type of turbo you use. There are many turbos that will give you full boost by 3500 rpms if you want it that way.
The only other advantage a SC max has over a turbo max besides price is that the stillen SC kit is fairly simple while a turbo set up gets a little messy trying to fit all the required piping.
Old Apr 7, 2004 | 09:44 AM
pawnstar12's Avatar
BUY MY CARS PLEASE!!!
SC's can suck my tail pipe
Old Apr 7, 2004 | 02:50 PM
well i would be more inclined to get a turbo because its only relying on whats being produced instead of being powering by ur alternator if you know what i mean. i think most on this board with agree with me on the grounds that any significant increase in hp is worth it. u can only get so much from air filter and intakes and exhaust systems. frankly i think the sc kit is way over priced, and like many we dont have 3k laying around that we can blow. so im just looking some other methods of a noticable hp increase.
so these def wont work?
Old Apr 7, 2004 | 03:16 PM
pawnstar12's Avatar
that is correct they wont
Old Apr 7, 2004 | 03:31 PM
well here you go u 5 speed i30 years 96-00 turbo kit
Old Apr 7, 2004 | 03:38 PM
brawhhahahaha i found a turbo and its better then the sc
http://www.turbo-kits.com/maxima_turbo_kits.html
300+hp safely on a stock engine, just alittle more then the sc i beleieve, and its all around better because most of us arent in the high RPM's daily, so the turbo is more efficient Brawhahahhaha now i think this settles some disputes that we have had over time
Old Apr 7, 2004 | 03:50 PM
pawnstar12's Avatar
the disputes were settled a while ago, sc's are for the noobs to forced induction or torque junkies. they cant run with my turbo at 6psi unless they are at 10psi or pumpin the go fast juice
Old Apr 7, 2004 | 03:53 PM
o sorry i didnt know i been following along for a while, i wasnt aware my bad
Old Apr 7, 2004 | 04:07 PM
I30tMikeD's Avatar
WTF are you talking about?
Old Apr 7, 2004 | 04:26 PM
pawnstar12's Avatar
lol......................ha ha
Old Apr 7, 2004 | 04:49 PM
thats what the specs said, i dont really know much about this, im just trying to learn it
Old Apr 8, 2004 | 12:34 PM
Marx's Avatar
This topic has been discussed som many times, on so many different boards I can't believe this still comes up.
the difference between 10lbs of boost from a SC and 10 lbs of boost from a turbo is nil. Boost is Boost.
The advantage of a turbo is not really its abidactic effeciency, but how easy it is to change the boost. With the right set-up you could run 5 psi around town, then with the flip of a switch be running 10. It also easy to overboost your engine this way, but lets face it. You have to be smart about this stuff.
The only way to increase boost on an SC is by changing pulley diameters.
Old Apr 8, 2004 | 02:13 PM
I30tMikeD's Avatar
We are talking about maxima's, well I30's, here and SC boost is not the same as turbo boost. With the one Votech SC available to us, full boost is not made until red line. A turbo will let you make full boost way, way, before that. Without a very expensive rebuild by vortech (almost the same price as the blower originally cost) all the boost you can run is 13 or 14 lbs until the the blower is over spun at 6500 rpms. I am not an expert on the subject by any means, but what is available to max/I30 owners does not suggest that SC boost and turbo boost are the same.
Old Apr 9, 2004 | 01:30 PM
Marx's Avatar
You're absolutly right. Which is why Turbo's are the better choice. But I was not considering how soon you build boost, rather dyno numbers and peak HP. Assuming RPM and Boost are equal, a combustion chamber doesn't care if the 12psi of air rushing in came from a Turbo or an SC.
For example, if you do a dyno run and both the SC and Turbo at a max of 10 psi, the peak HP will be about the same, and it will peak up near the top of the RPM limit. Besides, an SC is linked directly to the Engine ergo, the faster the RPM, the more boost, so every SC will build the most boost when it spins the fastest. ...Until, like you mentioned, you over spin a Vortech style SC to where it spins so fast it stops making boost, cavitation I believe.
Anyway.
Old Apr 9, 2004 | 09:30 PM
just another side question, does having a turbo or sc help with ur fuel economy at all? does it increase it? decrease it?
Old Apr 9, 2004 | 09:38 PM
I30tMikeD's Avatar
Anyway.
A roots type blower will make peak boost much earlier then the type vortech has for maxima's. But peak hp does not mean a whole lot, it's all about the most hp under the curve. A turbo will give much more total power under the curve then will the stillen SC. The peak power that the vortec is making for maxima's is not real useable power because it's only the last couple hundred rpms.
Old Apr 9, 2004 | 09:39 PM
I30tMikeD's Avatar
More air, more fuel, less gas mileage.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
BkGreen97
Apr 2, 2016 05:47 AM
09maxshawn11
Sep 30, 2015 10:28 AM
Keyno McMike
Sep 21, 2015 07:18 AM
