Windnoise & A Rattle
Old May 19, 2004 | 01:16 PM
djfergi's Avatar
Hey Fellas,
I have 2 questions. I'm sure it's been discussed before, but I cannot use the search tool due it being disabled.
I just noticed the other day that there is a slight wind noise coming from the left rear door. I checked the seal around the door and it appears to be okay. Is there a TSB for this?? If so, what is it?
I also have a rattle which sounds like it's coming from the right tweeter or cup holder area. I really can't seem to pinpoint it. Anybody having the same rattle? Are there any easy fixes?
Later
Old May 19, 2004 | 01:35 PM
NewLoveI30's Avatar
There is a windnoise TSB so you can take that to the dealer and they should fix it under warrantee.
As for the rattle, I have the same one somewhere near the right A-pillar. I have brought that to the dealer and the were not able to fix it.
If you do find a solution to the rattle, be sure to let me know.
Old May 19, 2004 | 01:39 PM
djfergi's Avatar
Thanks Man
My warranty has expired though.
Now, is this something that can be done while I wait, or would I have to drop the car off??
Old May 20, 2004 | 12:36 AM
2000i30cg's Avatar
Personally for rattles, i just start ripping panels off and taking them out. Then drive around some more. Usually I find something inside of the panel, or it was the panel itself. One time, I had a really small nut INSIDE the glovebox, between itself, drove me NUTS! If the rattle is the panel itself, I just added a little strip of adhesive rubber, and ususally I'm all set...good luck with your rattle. Btw i have no wind noise .. just the exhaust and the intake ... :P
Old May 20, 2004 | 07:43 AM
NewLoveI30's Avatar
I would like to, but the dash seems like kind of a PITA to remove. Maybe Ill start with the right door pannel and the A-pillar. Who knows I could get lucky and find the rattle in there!
user 11122324
42
Jul 18, 2022 03:35 PM
lrb6805
Sep 17, 2015 04:49 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
thenewguyy
Sep 12, 2015 11:12 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
