'98 I30 w/ G35 rims?
Old Jun 28, 2004 | 09:59 PM
skytower31's Avatar
Any '98 or similar model year I30s out there running G35 rims? What size and year are you running? Any special work to get them to fit?
Thanks!!!
Old Jun 29, 2004 | 06:57 AM
phenryiv1's Avatar
Mod her. Ate her.
No work is needed to make them fit, if you run the 17" size. The 18" may rub.
Actually, depending on the width and offset og the G35c rims, there may be rubbing. Once you pick a model of rim, let us know and we can advise you better. There are several models of G35 rims out there- we need to knwo which one.
Old Jun 29, 2004 | 07:18 AM
skytower31's Avatar
Well there are 2 that my friend is looking at. Either the 17" standard coupe rims running 225/50R17 front and 235/50R17 out back or the 18" upgrade rims running 225/45R18 front and 245/45R18 out back.
I think the stock rims on his I30 are 205/65R15 all around.
Diameter calcs come to this:
I30 205/65R15 = 25.5"
G35 225/50R17 = 25.9"
G35 225/45R18 = 26"
My biggest concern would be the offset and width of the tires. And the 235 or 245 out back may rub on the inside. Anyone have insight into this?
Old Jun 29, 2004 | 07:39 AM
phenryiv1's Avatar
Mod her. Ate her.
The 17" coupe rims should fit, and some people have run the 18" coupe rims, but you should consult the infiniti offset chart at the top of this forum for more info.
I woudl be worried about the rear 18s...
Old Jun 29, 2004 | 08:19 AM
skytower31's Avatar
I think the 18" 7 spokes are a little too modern looking to fit the look of the older I30. I think the 6 spokes or even the sedan 5 spoke would look good.
When looking at offset, is that the distance from the inner side of the tire to the innerside of the bolts or where is that measured from so I can take a few measurement on his car. Thanks!!!
Old Jun 29, 2004 | 08:41 AM
phenryiv1's Avatar
Mod her. Ate her.
Is he running stock I30 98 rims? Is it a regular or "t" model?
Old Jun 29, 2004 | 09:07 AM
skytower31's Avatar
Stock 25 or so spoke 15" non-t rims
They look like this:
Old Jun 29, 2004 | 09:45 AM
phenryiv1's Avatar
Mod her. Ate her.
Infiniti Offsets:
15" x 6.5" 96-99 I30 40mm
17" x 7" G35 45mm
17" x 7" G35 sport 45mm
18" x 8" G35 coupe 30mm
Old Jun 29, 2004 | 09:48 AM
skytower31's Avatar
So what does that mean? Where is that 5mm difference? Inside or outside?
Old Jun 29, 2004 | 12:48 PM
Weasel's Avatar
Anyone know the stats (width, offset) of the standard 17" G35 coupe wheels? I was told 17x7.5 front and 17x8 rear but I have an idea that they might be the same size wheel, just different tire sizes.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
uttadms31
Sep 30, 2015 05:24 AM
