Wheel spacers
Wheel spacers
Well I finally got sick of how far the rear wheels are inset, so I ordered a set of 15mm H&R spacers.
The install seems pretty straight forward, but I was just wondering if any of you have done this before.
I have heard that when I remove the rear calipers they will compress. Is this correct? Do I just turn the piston to reset it?
Any other helpful tips for the instal, or am I going to have to find out the hard way?
I don't think you need to remove the caliper. I am guessing your replacing the studs, but you should be able to get to one at a time by having the rotor in a certin spot. At least that is how it is on the the 95-99 I30's.
Originally Posted by Nismo
well you have to remove the caliper so you can take the rotor off but I dont recall having to compress the pistons back in for the rears.
I got them in the mail last night, and all I can say is that it is a shame that these have to go behind the wheel.
They are... Beautiful! HeHe
Anyway I hope it doesnt take too long because I have to pick up my sister in LA tonight. I dont think it will take too long, but I am usually wrong about these things
Mike, Ill try it first w/o removing the caliper, but dont the spacers have to go behind the rotor? Well, here I go spouting off before I have even looked at the situation.
Hope to let you know how it goes tomorrow.
They are... Beautiful! HeHeAnyway I hope it doesnt take too long because I have to pick up my sister in LA tonight. I dont think it will take too long, but I am usually wrong about these things
Originally Posted by I30tMikeD
But you should be able to do it without removing the rotor.
Newlove- the spacers go over the roter, between the wheel and rotor and if you have hub centric rings, they go over the spacers so its like: rotor-spacer-hub ring- wheel
Yea I guess so if you hammer the studs out but I used a ball joint clamp tool to press them out.
That is probably a better way since you don't have to put that stress of hammering on the hub.
Well I bought a 30mm hub bolt socket (think it may be a little too big, anybody know?), to use with my 1/2in breaker bar, and DAMN!!! That sucker is on there!
Maybe I will get some pipe to put over the breaker bar to give me some more leverage.
Any tips???
Any tips???
why are you removing your hub nut? all you do to remove the rotor is unbolt the caliper off the knuckle and the rotor will slide right off the studs. if its stuck, wack it a few times with a rubber mallet to break the rust loose.
I need to remove the hub because I need to replace the studs for my thicker spacers.
Originally Posted by NewLoveI30
Well, because Im not just trying to remove the rotor.
Do not remove the axel nut!
Sorry, I just dont really feel comfortable banging real hard on the hub. So am i correct in assuming that you didnt fuc-up the hub or bearing?
Now Ill just have to get the dust plate out of the way. I hope that wont give me too much trouble, or I may have to cut the thing off
I got the 15mm H&R, hub centric spacers. It seems like a really nice kit. The spacers are very light and come with the required longer studs.
I got them from www.optauto.com or something for under $100
Ill put some pics up on my site when I get done.
I have been meaning to get spacers as well. I don't know if I should go with 5mm front and 15mm rear or 15mm front and 20mm rear. I wish H&R made 10mm spacers for us. I can't stand my offset since going back to stock wheels.
Andy29
Sep 29, 2015 05:32 AM
