automatic transmission faulty code
Old Jul 24, 2004 | 08:53 PM
eastcoaster's Avatar
I have a '97 i30 and recently the check engine light came on. I got a code of 0504, which is the automatic transmission control unit. Is this something that is easy to replace or am I going to have to fork over some serious dough to fix this? The car otherwise runs well.
Old Jul 26, 2004 | 09:35 PM
i30ds's Avatar
Armed and Dangerous
I got this code about a year ago when I had just installed my Stillen FSTB. I discovered a part of the trottle postion wire/sensor wire loom had rubbed through on the Stillen bar and was grounding out. This then caused the transmission control unit fuse/relay to blow, and made the transmission go into safe mode, locking it in 3rd gear. After I replaced the fuse, it blew again, so I had to cut the throttle sensor loom bunle apart, and relocate about an inch away using heat shrink and solder. Even for a car savy person this was complete PAIN IN THE A$$, and took many, many hours of troubleshooting and repair!!! The cost was minimal, maybe $30 for the fuses/relays, but it ate up a lot of my time.
Good Luck!!
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
videomano
Sep 8, 2015 03:28 PM
