Hesitant gear shifting, please help!!!!
Old Jul 27, 2004 | 09:57 PM
PEARLYI30's Avatar
I have a 98 I30 and my gears are shifting with a delayin a sluggish manner. I have already been stuck in reverse about 2 or 3 times now where the car will not move and i had to press the pedal hard and it would like kick in and do a burn out reversing. I have also been at red lights waiting for green and when the light would turn green and i press the gas I dont move then when I press it hard it would all of a sudden just kick in. So what I need help with is knowing how to fix the problem. I dont know wether to get a new throttle body new tranny or what. I dont wanna go to a shop and they tell me I need a whole new tranny when really its something smller than that. So can someone help me out
Old Jul 27, 2004 | 10:10 PM
PAREDLINE's Avatar
check the fluid. If you can drain the fluid and change it. Get a bottle of Trans-medic or one of those high quality transmission additives. They use them at transmission shops too so I know Trans-medic works.
Sounds like your torque converter is toast. Or your clutches are binding.
Old Jul 27, 2004 | 10:32 PM
PEARLYI30's Avatar
I have had my tranny fluid flushed and refilled and still have this problem, so your saying you dont think I need a new tranny though?
Old Jul 28, 2004 | 10:22 AM
PAREDLINE's Avatar
I assume you have an automatic. Depending where you go you may not need a "new" transmission. What some shops do is they keep a fresh rebuilt transmission around. Then they do a swap and rebuild the one that comes off your car.
I think you need a transmission rebuild; at least a repair and internal inpection. Take it to AAMCO or a reputable shop for an estimate.
It will cost you anywhere from 700-2500 depending on what needs to be done.
You can ask about putting in another used tranny. Get it diagnosed at a shop first though.
Old Jul 28, 2004 | 08:58 PM
PEARLYI30's Avatar
ok thanks for the help
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
