Brake Fluid change ?!?
Old Sep 16, 2004 | 09:15 AM
flthere's Avatar
In MSN Enhanced Maintenance Schedule, the following items were given to be done at 105k. I was just wondering what it meant by Brake Fluid change. Is it sthg similar to transmission fluid change ?!? Is there a How To on doing brake fluid change ?!?
Procedure Action Labor Parts Total
Brake Fluid Replace $45.50 $12.00 $57.50
Windshield Wiper Blades2 Replace $13.00 $20.00 $33.00
Air Cleaner Filter/Element Inspect $26.00 $0.00 $26.00
Automatic Transaxle Fluid Inspect $0.00 $0.00 $0.00
Cooling System Hoses Inspect $0.00 $0.00 $0.00
and Clamps2
Safety Inspection (lights Inspect $0.00 $0.00 $0.00
, horn, wipers, etc.)
Old Sep 16, 2004 | 01:44 PM
i30ds's Avatar
Armed and Dangerous
Bleeding the brakes, is simply removing the old fliud from your brake lines. If you don't do this, your brake line will rust out. There is a bleeder bolt on the brake caliper, and use a 10mm box end wrench to remove the fliud. Also, have some one pump the brakes five or six times before losening the bolt so you can have greater pressure. Shut the bolt closed quickly before any air goes back in the caliper. Remember to refill the resevior after bleeding each caliper/ line.
pktaske
May 6, 2016 07:49 AM
BkGreen97
Apr 2, 2016 05:47 AM
captchaos
Mar 15, 2016 12:18 PM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
