airbag light
airbag light
just got the flashing airbag light turned off.....it was some connector inside the passenger seat that came lose for like a split second and set off the system. was fine for a while then somone got in pass seat and it went off again. so i have 2 questions first..anyone know a quick fix for this? and second if i get an obdII scanner can i turn off these lights by myself?
There is a connector in the airbag harness in the back of the seat. It can be eliminated by cutting it out and soldering the wires together. This will eliminate this connector as a source for future malfunctions. All it does is connect to an intermediate harness that goes out the seatback and to the connector at the floor. Infiniti later released a TSB on this issue, and would replace your airbags with ones that had a much longer wire, with no intermediate connector. This was of course only if you complained during the warranty period.
fastcarny
Oct 6, 2015 10:42 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
