H/O alternators available for a 98 Max SE?
Old Oct 7, 2004 | 07:30 AM
Wish-it-was-AWD's Avatar
Looking to find out if any other oem alternators "BOLT-UP" to the 98 VQ SE manual with no ABS. I need a unit that will push 150+ amps at idle for my stereo (high SPL and perfect SQ). Running an Alpine CDA-7949, JL XR 6&1/2"s, 5&1/4"s and tweeters up front, JL XR 4"s and tweeter for rear fill and JL W7s, either two or three 8"s or two 10"s. All Stinger Platinum interconnects, 1/0 AWG from stock battery to Optima Yellow top in rear, with battery isolator, a 1 farad capacitor, and all esoteric speaker wire. Will dynamat the doors, and trunk first, the roof, firewall and floor. Akps pushing them: Kicker ZR 240 for front, ZR 120 for rears, and a strong ZR600 to push the subs, probably in a sealed bandpass, tuned to @ 68 Hz, and vented either through the rear-seat console cubby trap-door, for lack of any better term, or through the rear deck (reinforced of course). I will be building custom fiberglass/MDF sealed enclosures for the components front and rear, and will attempt to keep it looking completely stock, or as close as possible without compromisinf SQ, i.e. factory grills, etc. Back to the question at hand; Are there any other alternative alternators available without having to go to Stinger/AAMP of America, as I had one that was perfect for my 98 Sierra Z-71, but quite costly. 160 amps at idle 220 amps at 2,200 RPMs. Even with a 12K lb. Warn winch running, two 210 watt **** Cepek lights, two 65 watt fog lights, low and high beams running simultaneously 85 and 110 watts each side, respectively, and my stereo blasting at idle, and even with the engine off for 15-45 mins. at a time, for 5 hours, it never dimmed, or hesitated when cranking. I still have it, and may simply try to re-wire it, change pulleys if necesssary (to get the proper number of ribs), and fab a bracket to make it fit. If not, another alternative may be to fab a bracket to run two alternators (stock or the highest available) and simply re-route the serpentine belt, getting a longer one of course. Anyone who has had any experience with this, your input would be greatly appreciated, as I have looked on the internet exhaustively and had no luck, and I can't seem to search "the org" because, though I have owned two maximas, I lost my old e-mail and access for a while (I was homeless for a year and a half, and therefore computer-less) so I've had to re-register as a green horn. Thank you in advance for reading this dissertation of a post and if you have any questions about anything at all, please feel free to ask; I would be homored to help/offer what knowledge I have to anyone who is willing to listen.
Old Oct 8, 2004 | 09:44 PM
ZeroSource00's Avatar
wow, what a long post in the wrong section
Old Oct 8, 2004 | 10:36 PM
Longboarderphil
go to www.h-oalternators.com...call them up the alternator is 750 for a 200 amp. i called and checked it out b4, i have a better source now to get the high output alt. but please put this is in the right section
Old Oct 10, 2004 | 06:44 PM
i30ds's Avatar
Armed and Dangerous
good lord! my head is spinning
Old Oct 10, 2004 | 08:43 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
Forum: Audio and Electronics 10-07-2004, 11:37 PM
Replies: 2 Any high output alternators for a '98 SE 5-spd
Views: 34 Posted By Wish-it-was-AWD
at what rpm? what output at idle?
Do you happen to know? Is it a direct fit? Available with and adj. voltage regulator? Just curious, too late to call now, so I figured I'd bounce it off of you. Do you know of any others who have...
Forum: 4th Generation (1995-1999) 10-07-2004, 05:41 PM
Replies: 3 High Amp alternators available for a 98 SE?
Views: 60 Posted By Wish-it-was-AWD
My Bad...cannabrutthagettado-ovah?
Sorry about the double post, I was desperate to find info, frustrated, and procrastinating writing a survey analysis for publication..too much caffeine, too little sleep. I won't let it...
Forum: Other For Sale/Wanted 10-07-2004, 09:32 AM
Replies: 0 WTB: H/O alternator for 98 Max SE
Views: 4 Posted By Wish-it-was-AWD
Looking to find out if any other oem alternators "BOLT-UP" to the 98 VQ SE manual with no ABS. I need a unit that will push 150+ amps at idle for my stereo (high SPL and perfect SQ). Running an...
Forum: Infiniti I30/I35 10-07-2004, 09:30 AM
Replies: 3 H/O alternators available for a 98 Max SE?
Views: 29 Posted By Wish-it-was-AWD
Forum: General Maxima Discussion 10-07-2004, 09:28 AM
Replies: 0 H/O alternators available for a 98 SE?
Views: 26 Posted By Wish-it-was-AWD
Forum: 4th Generation (1995-1999) 10-07-2004, 09:27 AM
Forum: Audio and Electronics 10-07-2004, 09:25 AM
TallTom
57
Oct 14, 2025 05:16 PM
litch
123
Jan 4, 2024 07:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
Marc2theMax
Sep 28, 2015 08:13 AM
