Help wanted abt re-aiming headlights
This link in 4th gen faqs explains the concept but it doesn't say whether there are any screws or sthg that can be turn left or right, up or down in Nissan cars. Can someone help me locate the screws in 4th gen ?
Thanks.
Thanks.
Thanks.
Thanks.
I have the cefiro one pieces and they are a bit different but IIRC there are four aiming screws. They are pretty easy to find. Open the hood and look behind the the back of the headlight. Just try messing with them at night with the lights on pointing at a wall or a garage door and you will see how they change the beam.
Originally Posted by Dr.Monkey1313
Do the Cefiros need to be aimed and adjusted after installing them??????
I just put my Cefiros in and drove. THey look good to me, but now I am curious.
Thanks.
Thanks.
ok cool, thanks. When I look at them on a wall (turned on) it looks to me like they are straight, but the beam sort of angles off to the right (passenger side) and up at a slant a little bit on both headlights. Do you see this as well with yours?
just curious.
just curious.
Yes mike, i actually happened to put silverstar in the right side to test and compare stock vs silverstar and somehow i see that the right side light aims slightly to the right like you said above and was wondering if i need to re-aim the rightside light but thx to your clarification ... i'm yet to put the bulb in the lefthand side ... juz lazy ...
vingodine
45
May 21, 2016 12:46 PM
