What does it mean when my window slows when rolling up??
Old Oct 20, 2004 | 08:39 PM
bmw m3 s50's Avatar
What does it mean when my window slows when rolling up? It only does it when rolling up? Is the motor going bad or does it need grease?
Old Oct 20, 2004 | 10:47 PM
Longboarderphil
your window regulator may be on its way out...try grease first. always try the cheap alternative first!!
Old Oct 21, 2004 | 08:34 AM
SuBXeRo's Avatar
i have the sdame problem and i swapped motors still have the same problem and i tried geasing it and it didnt help i sparyed sum silicon lubs onthe sides where the window hits the rubber and it helped alil bit, mines on my driver side you?
Old Oct 22, 2004 | 01:12 AM
bmw m3 s50's Avatar
LOL
I have the same car 1996 dark green plus I am in phila, my dad works in river edge so I am always out there! The window is the same as yours driver's window.
ANY ONE ELSE KNOW HOW TO SOLVE THIS!!!!
Old Oct 22, 2004 | 03:11 PM
i30ds's Avatar
Armed and Dangerous
It could be rubbing. I poped my panel off to do some work in there and I put the panel on incorrectly and the window rolled up all so as hell! I poped the panel off and put it back on and this fixed the problem. I doubt this is the exact problem you are having, but something else could be rubbing. Pop the panel and take a look at things.
Old Oct 22, 2004 | 05:35 PM
SuBXeRo's Avatar
OOo like in bergen county lol ask him if he goes on kinderkamack by the police and fire station
Old Oct 22, 2004 | 08:43 PM
Vrs818's Avatar
I had the same problem with my 01 i30, I changed that rubber line that goes all over the door, keeps it safe from rain(don't know the name of it). It goes inside the door too, near the mirror.
After that everything came back to normal. Hope this helps.
Old Oct 27, 2004 | 07:54 AM
roofadoofalus's Avatar
my 2001 makes a rather loud squeeking noise sometimes
Old Oct 27, 2004 | 12:46 PM
PhillyDonut's Avatar
i fixed this for a couple of people. My bro's accrod window was severely slow, but it went away after some silicone spay. Just make sure you have the inner rubber track covered nicely. a single spray is not going to do it, and let the silicone settle for a few minutes before applying a second coat (i used Q-tips to get inside). Then again, your situation may vary.
Edit: ALSO very important is applying silicone on the low rubber track!!! Meaning, getting it into the rubber piece where the glass comes in contact with rubber when the windown is fully down... this would mean 1) you need to take door panel off to get that deep or 2) ghetto rig a long spay line to the can that can be reach far enough down there. I have done both and honestly option 2 is a bit easier and worked just as well.
simple experiment: take off the door panel and remove the glass from the motor and try running the motor up and down (with some pressure on it) to see if it's struggling (sounds like a lot of work, but it's really not). better than being annoyed by a slow window or buying unnecessary stuff.
Old Oct 27, 2004 | 02:41 PM
SuBXeRo's Avatar
well i know its not the motor in my case i swapped two motors, but ill try ur idea
Old Oct 27, 2004 | 08:05 PM
let us know how it works
Fbana41
Aug 29, 2016 12:18 PM
D Mason
Jun 21, 2016 04:43 AM
Andy29
Sep 29, 2015 05:32 AM
