Fog Light Installation (Sorry if this is a repeat)
hey what can I say....BRING BACK THE SEACH FUNCTION!! ...anyway.....can anyone help me with replacing the fog lights on a 2000 I30? I just need some basic installation instructions. Is it necessary to remove the front fender? (etc etc.) thanks in advance for the help!
i'm just replacing the BULBS. Also, one mechanic just told me that I should be careful when replacing the fog light bulbs because it could potentially over extend the "lighting system" causing a shortage and possible damage ($$$). Anyone ever heard of anything like this. I am putting in regular H3 bulbs (Silverstars).....
He may have been talking about using higher-wattage bulbs - in which case certain problems can be associated with that. Silverstars shouldn't have a problem.
And the process mentioned above IS for replacing the bulbs (not the housing).
Yes it takes a little while, for the opening isn't in the most convenient place. I had to turn the wheels out of the way just to get into there. Then I had to unscrew 3 bolts in front of the wheel well under the fog light to remove the black plastic rain guards. Then you just find the back of the fog light housing, twist the seal off, and unclip the back of the bulb. Beware the bulbs ARE H3, but the mount is a little bigger than the clip on normal H3 bulbs. 30 seconds of sanding should make them fit just fine however, widen the rectangular gap. Then test them, and repeat the process in reverse.
vingodine
45
May 21, 2016 12:46 PM
Viralkill
Aug 17, 2015 10:54 AM
98nismomax
Aug 13, 2015 12:44 PM
