infiniti I30 engine life?
Old Oct 26, 2004 | 04:05 PM
chris1's Avatar
does anyone know if the 2001 infiniti 130's engine has a long life. i know if you drive right and keep up with your car it will last a good while. i just want to know if the infiniti has a good engine like the nissan maxima and the honda accord and civics. any replies would be appreciated. are they a good car for the price
Old Oct 26, 2004 | 04:12 PM
kcryan's Avatar
alright now correct me if im wrong but isnt it the same engine as the maxima? and i know for sure it will smoke civics and prob accords
Old Oct 26, 2004 | 04:13 PM
Jeff92se's Avatar
I'm needing a caw
Umm, Nissan owns Infiniti. So Infiniti engine = Nissan engine. You take care of the engine and it will take care of you. 200,00+ miles should be no problem.
Old Oct 26, 2004 | 04:22 PM
guysohigh's Avatar
SimStones
Engine Life
I've got a 96 I30, with 195K and we've never had a problem with it. I person I bought it from never had any problems with it. nissans are built to last, so engine life shouldnt be an issue
Old Oct 26, 2004 | 04:40 PM
kcryan's Avatar
ohh 195k is that on an auto or a manual?
chris1's Avatar
thanks guys...
i totally did not put 2 and 2 together. i didnt know if it was the same engine though
Old Oct 26, 2004 | 05:37 PM
flthere's Avatar
Will the transmissions have the similar lifetime like the engines ?!?
Old Oct 26, 2004 | 06:48 PM
kcryan's Avatar
thats what im wondering as my 98 with 75k on it (Auto) makes a sound when it shifts into one gear also when it shifts out and while its in the gear it humms and shakes the car. it worries me
Old Oct 26, 2004 | 07:29 PM
Dr.Monkey1313's Avatar
I have a 96 I30 and just hit 150K. I have not had any problems with either the tranny or the engine. Mine is an auto. From what I have heard from Mechanics, dealers, and people in general is that the engine and transmissions on these cars are some of the stongest on the market. SO far I believe them. My car still runs like a brand new car. I love it.
Old Oct 27, 2004 | 05:24 AM
Pizatt's Avatar
Looks like this question needs to be placed in the FAQs, especially the part about Nissan= Infiniti!
Old Oct 27, 2004 | 06:50 AM
guysohigh's Avatar
SimStones
Itz an auto and i Love it, the only thing i would change about my car would be to make it a stick
Old Oct 27, 2004 | 07:21 AM
I30tMikeD's Avatar
From my time on the org, and my own expierence, the motor can go 250K no problem but the car will usually go through two trannys by then. Espeically if you got a 5spd.
Old Oct 27, 2004 | 08:21 AM
flthere's Avatar
LOL.
I believe it's worth putting up a sticky on things recommended out of experience for periodic maintenance Not covered in factory manual but those which we really need to replace or service and the time period as well.
Old Oct 27, 2004 | 08:28 AM
2000Infinitii30's Avatar
I had my car at Infiniti 2 months ago for what I thought was a tranny problem, the tecs seemed astonished that the car would have a problem with the tranny due to the fact that there rarely if ever have any problems. After some investigation it turned out to me the Mass Air intake which was causing the car to shift poorly and have a horsepower loss. Long story short there tranny’s are built to last!!!
Old Oct 27, 2004 | 06:45 PM
kcryan's Avatar
u2 with the high milaege or anyone else up there do u guys use any additives(seafoam,mmo,chevron,zmax,slick50 etc etc)
Old Oct 28, 2004 | 06:01 AM
guysohigh's Avatar
SimStones
I just keep my oil changed regularly, get a fuel system flush maybe once a year, most of the miles are highways miles, so the car isnt' as beat up as most people would think.
Old Oct 28, 2004 | 04:58 PM
i30ds's Avatar
Armed and Dangerous
92k Auto here... clean crisp ****fs every time... The wierd thing about our cars is that the AUTO is more reliable than the MANUAL.
My friend has a 96 I30t manual with 125k and he is on his 2nd tranny and 2nd set of tranny bearings as well... NOT GOOD... That is why I am dropping in a 98 or later manual so I can be assured that the bearing issue has been revised.
kcryan: your problem could be from a bad VSS. Got any CELs?
Old Oct 28, 2004 | 05:19 PM
kcryan's Avatar
no check engine lights i can see if the ecu has anything in it if that would help. this sound only occurs at about 37-42 mph in the 1500 rpm range and never if the od is off. it thunks into the gear vibrates and growls then thunks outta the gear.
any help would be greatly appreciated
what does vss mean? varible speed sensor?
Old Oct 28, 2004 | 05:31 PM
i30ds's Avatar
Armed and Dangerous
Close... vehicle speed sensor, and if is malfunctioning, it can be cause for irregular shifts. I would get a reputable mechanic to diagnose the problem, beacuse auto trannys are so complicated it could be anything.... You will chase **** around forever.
Old Oct 28, 2004 | 05:41 PM
kcryan's Avatar
it seems to have no prob finding the right gear it just doesnt like this one part of OD ill get it checked out sometime. i think it needs a flush personally.....is there any way to check the quality of my fluid
Old Oct 29, 2004 | 02:15 PM
i30ds's Avatar
Armed and Dangerous
Just look at the fliud color on the dip stick.
Red = Good, Brown = bad
Old Oct 29, 2004 | 02:57 PM
kcryan's Avatar
its red..........
Old Oct 29, 2004 | 03:00 PM
i30ds's Avatar
Armed and Dangerous
Then it is not dirty fluid that is causing your problem... Your fluid could be dirty and due for a flush, but only a **** brown color will make for sh!tty shifts. Something else is wrong....
Old Oct 29, 2004 | 03:56 PM
kcryan's Avatar
hmmmm any ideas?
Old Oct 31, 2004 | 08:38 PM
i30ds's Avatar
Armed and Dangerous
auto trannys are so complex that a qualified mechanic with all the diagnostic tools is the only one that could solve the problem. Just have him identify the problem, and if is is something simple, like a bad VSS, then you can fix it yourself and save the money.
Old Nov 1, 2004 | 06:49 AM
I was told my Infiniti whne I brought my car in to be fixed that there Tranny's NEVER go out he said he worked there for 6+ yeasr and saw one. Whitch was pretty good cause I thought I was replacing my tranny for sure, but he told me otherwise.
Old Nov 1, 2004 | 07:11 AM
I30tMikeD's Avatar
I can't vouch for anything but I30's, but my tranny went on me at 100K. Maxima's have tranny problems, 5spd in particular, auto's are not too bad but definately not the strong point of the car. So if maxima's have problems then the I30 is no different.
9aj9
Apr 5, 2020 12:11 AM
Mar 12, 2020 12:06 AM
RinconI30
Nov 10, 2015 10:55 PM
