O2 sensors
Old Nov 3, 2004 | 10:19 AM
2000Infinitii30's Avatar
O2 sensors
Please excuse my ignorance, what exactly do O2 sensors do. When they go out what problems do they cause? I ask because I think my rear O2 sensor is out and the car is running perfect. Is this something I should worry about replacing? Or just get my SES light reset.
Thanks for your help!
Old Nov 3, 2004 | 10:54 AM
flthere's Avatar
The emissions test will fail for sure. Simple reset won't work.
Old Nov 3, 2004 | 12:12 PM
attomica
There are four O2 sensors on your car, two before the cat and two after, so make sure your targeting the right one(s). Their purpose is to monitor the exhaust gasses and cause the adjustment of the engine's timing, firing, etc. (based upon the readings) to maintain optimum performance, efficiency, and clean emissions.
I just had this exact probem resolved on my 2000 at the stealership. The front two sensors needed replacing and they were happy to do it for a mere $560.
If you're sure a sensor is the cause, you can replace them yourself. I found our O2 sensors on www.oxygensensors.com ranging from $60 to $100, depending on if you want OEM or not.
I'm not sure how you'd have the SES light cleared if you were to do the replacement yourself, though.
Old Nov 3, 2004 | 06:03 PM
i30ds's Avatar
Armed and Dangerous
After any repair like that the CEL must be reset... the instructions are in the 4th gen forum. All you need is a flathead screwdriver and 5 min.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
