interior light problem
Old Nov 5, 2004 | 01:01 AM
cefiro8701's Avatar
one of my door lights went out...i changed bulb it sparked and then...dead...what happened?i keep trying with different bulbs...i know its not the fuse because all the other ones worked...so what happened?do i need to change anything?HELLLPPP!!! y cant anything be easy wid this car?
Old Nov 5, 2004 | 04:23 AM
I30tMikeD's Avatar
Are you trying to use ulta hyper HID style tuner LED's
Old Nov 5, 2004 | 06:43 AM
cefiro8701's Avatar
no....it happened when i was just changing them for no reason....they were actual 194's....
Old Nov 5, 2004 | 09:13 AM
Colossus's Avatar
My driver side interior bulb doesn't work at all... I need to get out the multimeter and find out where the signal dies
Old Nov 5, 2004 | 09:46 AM
Longboarderphil
same happened to mine but on the passenger side...i have no idea what the hell happened...it worked fine b4, then i went to change bulbs and then it crapped out
Old Nov 5, 2004 | 10:15 AM
Max Mutes's Avatar
Damn, I wanted to change all my interior bulbs to Hyper white, like Polarg or PIAA...still want too, but questionable if I will now.
Old Nov 5, 2004 | 12:50 PM
Dr.Monkey1313's Avatar
You may want to take your door pannel off and check to make sure the wire for your door light has not slipped out for some reason. (That is if your light is not working at all) If you got a spark and then it went out, take the door pannel off and check to make sure the wire is not missing insulation anywhere and touching metal. Just a thought, but maybe it is shorting out becuse of that????
homeyclaus
Sep 3, 2015 06:15 PM
rbaker100
Aug 28, 2015 08:11 PM
Jeffesernia11
Aug 23, 2015 06:09 PM
Samedi
Aug 13, 2015 04:05 PM
yat70458
Aug 3, 2015 01:16 PM
