96 I30 Automatic tranny question
Old Nov 5, 2004 | 11:00 PM
Mikey535's Avatar
hey guys i need your help..
i need to change tranny fluid, but manual not saying how many quarts?
Also how do i remove drain plug...? or just me.. having hard time to removing it. there's no infiniti dealer near my home town, i was woundering if i could use maxima drain plug?
How many quarts do i need?
can i used maxima drain plug for replacement?
how can i remove plug...? having hard time...?
please help me... !!!!!!!!!!!!!!!!!
Old Nov 6, 2004 | 12:03 AM
talisman311's Avatar
a full drain will be around 5 quarts of atf, if you're sticking with the conventional stuff use mobil 1 atf, otherwise mobil 1 or amsoil atf. since the vq30de is used in both the maxima and i30 you can use a maxima drain plug. you don't need to change the drain plug though, the most important thing in my opinion is to replace the crush-ring. 70 cent part. as far as removing the plug goes, it should just be 14mm if my memory serves me correctly, if you're having that hard of a time get soem penetrating fluid and a breaker bar.
Old Nov 6, 2004 | 12:10 AM
Mikey535's Avatar
thanX talisman311...
what is crush-ring? is it plug drain seal?
do i need to remove 23 bolts to change AT fluid or remove just one bolt that locate middle of pan? kind of confuse....
this is my first time... do it my self...
Old Nov 9, 2004 | 12:00 PM
i30ds's Avatar
Armed and Dangerous
You do not need to replace that ring just use a good layer of ultra blue silicon sealer on the bolt (over the copper ring), before you put it pack in the pan. After draining the fluid from the tranny using the drain bolt, remove the 23 bolts and drop the pan, so you can change out the filter, and replace the pan gasket. Also, do not forget to clean the sludge/ metal shavings from the pan and pan magnet.
NEVER go by the recommended fluid amount in the manual. YOU WILL OVER FLOW THE TRANNY. You MUST fill the tranny via the dip stick tube in 1/4 quart incraments, constantly checking the fluid level on the dip stick. The engine must be warm and move the tranny into each gear EVERY TIME before checking the fluid level. Once it is in the middle or near the upper dot, the fluid is at the correct level.
Mar 12, 2020 12:06 AM
Maximan190
Dec 16, 2015 06:01 AM
RinconI30
Nov 10, 2015 10:55 PM
pktaske
Sep 4, 2015 08:40 AM
