1998 i30 touring without a spoiler
Old Dec 4, 2004 | 11:17 PM
r5clp's Avatar
Hi,
I am about to buy 1998 i30, the seller claims that it is a TOURING model, but the car does not have a spoiler.
Is there a way to check it?
Old Dec 5, 2004 | 07:28 AM
infintishock's Avatar
I don't think any I30t's came out of the factory without a spoiler. I don't know if there is a technical way to check via the Registry or by using a VIN number, but there are other things you can look for on the car. The emblem on the trunk will say I30t instead of I30, there will be white faced gauges and wood trim on the steering wheel, and different wheels (you'd have to look up what the touring wheels look like, I can't really explain them). I don't know if you could check the suspension, but that would be different also.
Did I miss anything?
Old Dec 5, 2004 | 10:38 AM
kkashi04's Avatar
I don't think I30t's came with white faced gauges...those were on the Maxima SE's only but not on the I30's. And the wood trim on the steering was on the '99 Limited models only I believe?
Also, the t's had traction control and heated seats/mirrors standard along with VLSD(5sp only?).
But other than that, pretty much what infinitishock said.
Old Dec 5, 2004 | 10:42 AM
MaximaZero's Avatar
Needs non-Maxima Friends
You can check the wheels. The 98 touring models had 5 spoke wheels
Old Dec 5, 2004 | 10:52 AM
Max99ES's Avatar
The easiest way to check is by looking at the steering wheel.
This is for I30.
This is for I30t.
Old Dec 5, 2004 | 11:34 AM
Ah, yes I believe you are correct about the white faced gauges. My mistake!
Old Dec 5, 2004 | 02:58 PM
I30tMikeD's Avatar
If it is a "t" it will have a "t" on the trunk
Old Dec 5, 2004 | 04:34 PM
I was just thinking that perhaps a reason why there is no spoiler is that the trunk was replaced? In which case it may or may not have the correct emblems if the trunk was taken from a junkyard or something.
Probably a longshot, though.
Old Dec 5, 2004 | 07:50 PM
I30tMikeD's Avatar
Possibility
There are some basic guidelines to look for when it comes to determining which model an I30 is, but when it comes down to it a customer could have had there I30 equiped anyway the wanted.
Old Dec 5, 2004 | 07:51 PM
r5clp's Avatar
Thanks everybody,
The car is standard, not touring.
Old Dec 7, 2004 | 02:13 PM
jams's Avatar
I know thas has already been resolved, but the touring does not necessarily have traction control and heated seats. My 99 t doesn't.
Old Dec 7, 2004 | 05:55 PM
The heated seats were moved from the standard list to the options list in 1999, and the traction contol was made a new option for autos.
Old Dec 9, 2004 | 02:55 PM
i30ds's Avatar
Armed and Dangerous
Incorrect. www.consumerguide.com is wrong. Heated seats were always an option and so was the limted slip diff (traction control) for autos for 96-99. It was the 99 Maxima that finally had the option of the traction control lsd.
There were three main types of I30s.
First, there was the base model, which came with cloth, bose, ABS, heated mirriors, 15'' wheels, and open end differential five speed manual tranny standard. Auto tranny, limited slip differential (traction control), sunroof, leather, heated seats/ low washer fluid warning light, sport suspension (stiffer struts and springs), sport wheels (15" BBS 96-97, 16" Nissan 98-99), and spoiler were all optional.
Second, was the leather model, which came with leather, sunroof, bose, ABS, heated mirriors, and open end differential auto tranny standard. Manual tranny, limited slip differential (traction control), heated seats/ low washer fluid warning light, sport suspension (stiffer struts and springs), sport wheels (15" BBS 96-97, 16" Nissan 98-99), and spoiler were all optional.
Third, there was the touring model, which came with leather, sunroof, bose, ABS, heated mirriors, limited slip differential (traction control), five speed manual tranny, sport suspension (stiffer struts and springs), sport steering wheel (98-99), special floor mats (98-99), spoiler, and sport wheels (15" BBS 96-97, 16" Nissan 98-99) standard. Auto tranny, heated seats/ low washer fluid warning light, were all optional.
There was a limited model in 99 which came with leather, sunroof, bose, heated mirriors, limted slip differential (traction control), auto tranny, chrome kick plates, wood/ leather steering wheel, Q45 shifter, and two-toned paint, and special floor mats.
Options like the chome wheels, in trunk CD changer, and splash guards were options for all models.
The important thing to remember is that the I30 was a car that was fully customizable, i.e. it could come anyway the original owner wanted it. So different options are on different models.
Old Dec 9, 2004 | 08:05 PM
I stand corrected, thanks for the info.
Old Dec 9, 2004 | 08:33 PM
mikeI302k's Avatar
the factory had an option to remove the spoiler. as they did foir the a33 I30t
Old Jan 2, 2005 | 10:41 PM
130t_driver's Avatar
just check the title
Old Jan 2, 2005 | 10:42 PM
also the registration
Old Jan 3, 2005 | 04:42 PM
cmuehlenb's Avatar
I have a 2K I30T with no spoiler. Spoiler and side effects was a $1000 option.
Fbana41
Aug 29, 2016 12:18 PM
uttadms31
Sep 30, 2015 05:24 AM
jerrod99_se-l
Sep 25, 2015 03:02 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
