My Car is starting and then Dying right away...
Old Dec 9, 2004 | 04:21 PM
Gnstrolv's Avatar
Hello Fellow enthusiasts,
I did research on it and it appears that it could be a coolant temp sensor or a dirty throttle body right? Well I scanned the codes and it throws the PO325 or knock sensor code. I really don't believe that the knock sensor causes my car to die right after starting, unless I give it some gas then it is fine. I believe it is there as a side effect of the real problem. What do you guys think?
J-Rod
Old Dec 11, 2004 | 05:17 PM
i30ds's Avatar
Armed and Dangerous
Well, you know that KS is bad from that CEL, so replace that and then go from there.
A bad KS will give you up to 5 mpg less along with 20 hp loss. Replace it no matter what.
Old Dec 13, 2004 | 09:29 AM
Gnstrolv's Avatar
Thanks man.
I cleaned the throttle body cleaning and it did make a difference. I started it after it was off for a long time and it stayed on. The rpms are a little up ~100 and that was enough i hope. I will reset the ECU and then check later to see if that code is still there.
J-Rod
Old Dec 16, 2004 | 04:16 PM
SKORPiO's Avatar
J-Rod
I did the same thing yesterday and boy what a difference certainly brought a smile to my face
regards, Bart.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
Maxboy23
Aug 11, 2015 11:59 AM
