96 i30 Mirror
Old Dec 26, 2004 | 09:17 PM
mwstjohn's Avatar
96 i30 Mirror
Is there any way to tighten the mirror in an i30? The mirror I have constantly swings down and will not stay in the posistion I adjust it to. There seems to be some sort of fastener on the top of the mirror, but it seems impossible to get any kind of a tool in to reach it.
Old Dec 27, 2004 | 10:31 AM
Dr.Monkey1313's Avatar
I assume you are talking about the rear view mirror. If so, then I would suggest getting an auto dim mirror with digital compas and replacing your rear view mirror. The install is very simple and you can get them for about $20 or so on Ebay. It is a two wire install ground and power. The only thing is that you will need to mount it on the windshield instead of where your mirror is now.
If you do not want to do the above, then I would suggest you remove the rear view mirror from teh roof of the car and try tightening it that way. (you mentioned that it is hard to get tools up there with the mirror attached)
I used to have this problem due to base in the car, so I just replaced the mirror with a windshield mounted one. I love mine!
Hope that info helped you. Good luck with it.
Old Dec 27, 2004 | 10:31 PM
Luigi38's Avatar
if you are talking about the rear view mirrow there's a small screw in the back that you can adjust with a small screw driver.
Old Dec 28, 2004 | 08:27 PM
HomerMAC's Avatar
Donating i30 Owner
yea... what luigi38 said... i used ot have the prob of the mirror moving too .. but now just comming down like urs.. but jsut moved easily if it hi *** slightily.. so i tightened the screw now its nice and stiff...
Old Jan 6, 2005 | 04:16 PM
mwstjohn's Avatar
thanks for all of your help!
RinconI30
Jun 11, 2016 08:25 PM
RinconI30
Nov 10, 2015 10:55 PM
uttadms31
Sep 30, 2015 05:24 AM
jerrod99_se-l
Sep 25, 2015 03:02 AM
Bluenissan
Sep 20, 2015 08:54 PM
