lowest set of springs?
Old Jan 3, 2005 | 09:21 PM
cefiro8701's Avatar
what provides the lowest ride height??everything is less than 2.00 i want anything over 2.00
Old Jan 3, 2005 | 10:06 PM
cefiro a32's Avatar
I just had a set of springtechs installed and the drop is perfect. 2" in front and 1.8" in the rear. If you want to go lower than that you need to get some coilovers. I wouldnt recommend it though, unless you want to use your car strictly for show. The ride will be stiff as hell as well.
Old Jan 3, 2005 | 10:10 PM
cefiro8701's Avatar
really?i dunno...i really wanna go lower...im leaning more on the looks side...if i change my shocks shouldnt that help???
Old Jan 4, 2005 | 07:06 AM
I30tMikeD's Avatar
Both sprint and tein s-techs are more than 2". It will look good, but there will be almost no suspension travel left and you will be bottoming out alot. It is just they way our suspenison is designed. The car will actually handle worse with that low of a drop because of the lack of suspenison travel.
Not all coilovers are going to be really stiff, you can choose the spring rate you want with coilovers, as well as adjust the the strut stiffness and ride height. Coilovers will allow you to go as low as you want while maintaining suspension travel.
Trying to go lower than 2" with regular springs is very hard on struts. You will have to go with Tokico Illuminas if your going that low.
Old Jan 4, 2005 | 12:48 PM
thephatOne's Avatar
im going to kyb agx on tein stechs hopefully itll be a good ride, need to do rsb and a fstb in the next month or so, thatll complete my suspension mod, then itll be intake and full exhaust with magnaflow...i dont get the whole craze with cattman, frankencar etc... magnaflow has awesome mufflers and along with 2.5in mandrel bent from my exhaust shop i think itll match any of those exhausts' performance
Old Jan 4, 2005 | 02:09 PM
Gates's Avatar
If you want a good ride, spend a little more for the Illuminas. The AGXs are pretty stiff.
Old Jan 4, 2005 | 03:40 PM
I30tMikeD's Avatar
You sure your exhaust shop can do mandrel bends?
Old Jan 6, 2005 | 11:39 PM
cefiro8701's Avatar
would these do?
http://www.eautoworks.com/html/ORD-A...g-no-24365.htm
Old Jan 7, 2005 | 12:12 AM
I30tMikeD's Avatar
Originally Posted by cefiro8701
I would rather go with the lowest springs than the cheapest coilovers.
Old Jan 7, 2005 | 03:06 AM
cefiro8701's Avatar
i thought so too...does anyone know anyone with Htechs on?i need to see what 1.6 drop looks like...also..what is a better choice...i got a place that will give me stechs 180 shipped...and htechs 200 shipped...which is the best bet??i want style/comfort...not so much performance...i hate bumpy rides...
Old Jan 7, 2005 | 07:45 AM
I30tMikeD's Avatar
Then H-techs are what you want. They are a nice quality spring. 1.5" drop is about what my car is dropped
Old Jan 7, 2005 | 08:42 AM
Max Mutes's Avatar
The H-Techs or H&R's. H&R's give you a slightly softer ride, while H-Techs give you slightly better performance. Drops are very close, H-Techs might be a tiny bit lower but I don't know. Some cars take the same springs and struts and are a little lower than others so you can't really go by that. All I know is PHenry has a writeup on the H-Techs when he first installed them a while back. It was very good.
Old Jan 7, 2005 | 01:21 PM
cefiro8701's Avatar
do u happen to have any pics??i would like to see the gap clearance and what it would look like on my car...also...im doing this before i put in my 18's and i want that damn wheel gap gone...
imported_Nismo_max
Feb 17, 2016 03:39 AM
alphakaoz
Sep 30, 2015 07:33 PM
Stagnet04
Sep 13, 2015 09:32 PM
ef9
Sep 10, 2015 10:35 PM
