smell of gas from heater
Old Jan 7, 2005 | 01:23 PM
anton9881's Avatar
Recently whenever I get in my car and turn the heater on, an aroma of gas arises. It started a few weeks ago. At first, it was barely noticeable but it has progressed to the point where I am almost coughing. Does anybody know what could be wrong with my heater? I need to get this fixed before I: die due to gas poisoning, or my car explodes when a spark is present. Any helpful responses are much appreciated.
Old Jan 10, 2005 | 11:45 AM
98i30's Avatar
Is your climate control set for in Internal Air or External Air?
How many miles?
Old Jan 12, 2005 | 01:20 PM
cmuehlenb's Avatar
I have a 93 maxima that does this. The problem is cracked, leaky fuel lines in the engine compartment. When the car is sitting and warming up, the fumes get blown into the car thru the vent intakes when the heater is on.
Old Jan 12, 2005 | 02:28 PM
anton9881's Avatar
It has 136000 miles. Is there any way I can test the fuel lines? I am losing a lot of gas due to this. I am down to about half a tank of gas and I've driven less than 100 miles so far.
Old Jan 12, 2005 | 02:43 PM
cmuehlenb's Avatar
I would turn the key to on. Then check in the engine compartment for leaks. It has a high pressure fuel pump, so if there is a leak, you should be able to trace it...especially if you are loosing fuel that quick.
(Don't smoke while you are tracing)
It probably rubber fuel lines that are leaking. Make sure you replace them with the high pressure type.
Old Jan 13, 2005 | 12:31 PM
anton9881's Avatar
I had a mechanic check it out and he couldn't find a leak. Would you guys advise me in just changing all the fuel lines? How costly/difficult would that be?
Old Jan 13, 2005 | 02:10 PM
cmuehlenb's Avatar
On the max it is easy and accessable. Just buy high pressure 5/16 rubber fuel line from the autoparts store and replace all the rubber fuel line you can find. It won't cost much if you do it yourself. You should double check the size though.
My max is a 3rd gen, I am not sure about your 4th gen.
howardis
Dec 11, 2019 06:10 PM
maxinout93
Oct 31, 2015 02:04 AM
ef9
Oct 4, 2015 08:43 AM
