Cefiro headlight wiring
Old Jan 24, 2005 | 04:17 PM
Davis81387's Avatar
I need to know which color on the harness for the Cefiro one piece headlights goes with which color on the existing headlights. My low beam is actually high beam and my high beam is low so something is not wired correctly. Also does anyone know where I can get the adapter pieces for the turn signals and the smaller light underneath the headlight so I can splice them to the existing wiring? I bought them from a seller of here and they didnt send those parts. Any info would be helpful. Thanks.
Old Jan 24, 2005 | 06:28 PM
Davis81387's Avatar
I found the other adapter piece that goes to the small light underneath the headlight but I still need the adaptors that connect the turn signals to the existing wiring. I have the piece that actually holds the bulb but not the wiring adapter.
Old Jan 25, 2005 | 03:47 AM
Pizatt's Avatar
An adapter for the corner lights? Fukk that, slice a tiny notch in the lights and stick them in, I didnt change the harnesses and havent had any problems
If your high beam is your low beam etc... its simple... switch them... Trial and error my friend.
not to be a d!ck or anything, but please do a search within this forum... many people have done write ups on Cefiros
Old Jan 25, 2005 | 07:22 AM
iRaMarine's Avatar
I believe search functions are still disabled for us non-donating members, but the FAQs are available and seem to be an untapped resource lately.
Old Jan 25, 2005 | 09:25 AM
I30tMikeD's Avatar
Yes, you do not need to have the stock cefiro connector for the turn signals. The stock one will fit in there just fine with a little modification. I use a exacto knife to cut mine to fit.
The "city light" or as you refer to the smaller bulb next to the headlight can be spliced into the stock wiring.
For you high/low beam problem you simply have those wires reversed.
Old Jan 25, 2005 | 10:38 AM
Davis81387's Avatar
Thanks for the help but some of you didnt have to be so freakin mean I mean damn.... I'm not a pro (thats obviously why I'm asking questions) Anyways does anyone know what type of bulb I should buy for the city lights?
Old Jan 25, 2005 | 10:58 AM
Luigi38's Avatar
I think they are 194, they are the same ones that go in the speedoemter cluster, if 95-97. And the same ones that go in the door light.
Old Jan 25, 2005 | 04:17 PM
Davis81387's Avatar
Okay I got the 194 bulbs and they don't fit. Is there some kind of modification needed for them to fit the Cefiro adapter? Also, when do they actually work? Right now I've got the stock harness in the Cefiro housing (which it doesn't exactly fit but I've got it stuffed in there) I've turned on my parking lights and headlights and I never see the "city light" bulb light up. Is it during the turn signal or what?
Old Jan 27, 2005 | 10:40 AM
Davis81387's Avatar
Are the city lights even really necessary?
Old Jan 27, 2005 | 10:43 AM
I30tMikeD's Avatar
nope, I have had mine disconnected for a long time now
Old Jan 27, 2005 | 11:41 AM
Pizatt's Avatar
Even if you go through the last ten pages or so, I am sure there is someone asking about Cefiro lights.
Pizatt's Avatar
The only time i see my city lights are when i remote start my car, flash with my turn signals. They are useless lights that you should really worry about.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
