Ceramic Brake Pad Noise
Old Feb 14, 2005 | 03:59 PM
adam-99GLE's Avatar
I installed brembo rotors and satisfied pro ceramic brake pads from tirerack a bit back and have been hearing almost a grinding noise, but more of a creeking, from the front left brake, it comes with a slight vibration on the brake pedal as if the pads were gone and tearing into the rotor. I took it all apart cleaned it and put it back together and still have some brake noise. Happens much more noticibly when the car slows from about 15 to stop. Could this noise be the ceramic pads braking in with the rotor? Has anyone installed ceramic pads and had this problem? Possibly a defective part? Im lost here and can't stand the noises.
Also...Does anyone know where I can but interior chrome replacement handles for a 96i30. Paradox had them but apparently ran out. Anyplace else?
Old Feb 14, 2005 | 04:39 PM
illmortal's Avatar
From what I understand that brake setup is for street race to course race which means they are great for high speed breaking... so I think you might have to deal with the squeal unless you'd like to purchase squeek-gone for your break pads... it's like a lubricant.
Old Feb 15, 2005 | 09:49 AM
NewLoveI30's Avatar
Did the kit come with shims? Ha dthe wrong shims on my old car and those brakes would groan a bit.
BTW, I thought we had ceramic pads from the factory?
Old Feb 17, 2005 | 12:45 AM
adam-99GLE's Avatar
illmortal: Weak.
What are shims, the metal brakets or the metal back pieces? Or something else? Where can I buy squeek-gone and what are the downsides?
Old Feb 17, 2005 | 01:35 AM
Zeus97MAX's Avatar
Adam, the shims are thin sheets of metal that go between the brake pad and the rotor. You normally apply the anti-squeal in between the pad and the shim. I just re did my rotors and pads today, and used new shims, along with the lube. You can get the brake quiet at any auto store normally in the same area as the brake cleaners. I bought Akebono pads, and they came with new shims. You might need to use the old ones on your car, or order a hardware kit for the brakes which I think includes new shims, and new pad retainers.
Old Feb 18, 2005 | 07:26 PM
adam-99GLE's Avatar
Came with new shims, ill look for that brake quiet. I used lubricant and a cleaner before putting them on but...
Thanks for the help.
Old Feb 18, 2005 | 08:14 PM
illmortal's Avatar
hm... weak?
lol nevermind.
Old Feb 19, 2005 | 12:25 AM
I30tMikeD's Avatar
You shouln't be getting that much noise with new pads. Installed new rotors and ceramics before the winter I never heard a peep from them
Old Feb 21, 2005 | 08:42 AM
Aidan2474's Avatar
I've had some weird noises with my drilled and slotted rotors and cermaic pads,.. I hate it too but nothing I could do to get rid of it , and I tried everything
Old Feb 23, 2005 | 05:14 AM
Pizatt's Avatar
You might want to go with some Quiet Stop pads... Havent had a problem out of them yet and they hold up to my drilled and slotted rotors
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
