96-99 Infiniti I30 - Suicide Doors ???
Old Feb 16, 2005 | 07:49 PM
Dr.Monkey1313's Avatar
OK guyes, check this out. This site says it has suicide door kits for our cars. WOW! Take a look.
http://www.andysautosport.com/produc...uicide%20Doors
Here is the link to the main I30 part of the site if you are interested in seeing any other things they
offer.http://www.andysautosport.com/models...iti&id=In96I30
Old Feb 16, 2005 | 08:23 PM
cefiro8701's Avatar
too bad its not cost effective...although a suicide/lambo combo would look nice on a four door...maybe not tho...
Old Feb 16, 2005 | 09:49 PM
Gates's Avatar
I think it would look really weird and over the top on our cars. Maybe if you have a fast sports car but on a luxury car? I've seen pics of a Z roadster than looked really nice. You'd have to do all 4 doors somehow or I think it would look horrible.
Old Feb 17, 2005 | 04:01 AM
HomerMAC's Avatar
Donating i30 Owner
...= \ what tha... thats a horrible idea i think
.. but i guesss if u like it go for it
Old Feb 17, 2005 | 04:21 AM
Max Mutes's Avatar
Yeah man, I seen this one pic of a Black/Black 350Z and DAMN I was in love. It was amazing.
As for these doors on our cars, I wouldn't like the vertical type suicide doors like Lambos got, but I would certainly be interested in doin my rear doors to open opposite of the front. I'm not sayin I'd do it, but I'd def. be interested in how it would look, as that would be alot more classy, yet different and unique.
ie: Passenger Side >> \__l__/
Old Dec 8, 2005 | 02:34 PM
Tim96I30t's Avatar
suicide the backs so they open like an old lincoln continental covnertable that would look nice
Old Dec 8, 2005 | 02:42 PM
guysohigh's Avatar
SimStones
I was thinking the exact same thing, it made the lincoln pimp, and itz the only thing of the sort i would do that my car
Old Dec 8, 2005 | 06:46 PM
C-sideCefiro's Avatar
Now what?
I found out that I have to remove my entire oor pannel to replace my side view mirror but how do I do that with out breakng anything
Old Dec 8, 2005 | 07:25 PM
Tim96I30t's Avatar
you make your own post,just look at the door panel its pretty straight foward, handtools
Old Dec 8, 2005 | 09:42 PM
KRRZ350's Avatar
It's easy, just disconnect the battery, get a can of fix-a-flat, and then run a 3 foot long screw driver down the glass, from the inside. You have to make sure you insert the screw driver alongside the glass at the point DIRECTLY above the door-lock ****, also, be careful not to scratch up the glass. push the screwdriver down as far as it can go before the screw driver handle hits the top of the door panel. Once it's all the way down in there, grab it with both hands and simply pry back on it as hard as you possibly can, you have to really put your body into it and force it as hard as you can, once you hear a snap/crack/bang sound you'll know you broke it, umm, broke it loose that is..... When you're all done use the fix-a-flat to seal everything back up nice and tight.
Old Dec 9, 2005 | 04:04 AM
cefiro8701's Avatar
two screws in the bottom...then one in the arm rest....unscrew those..
remove the door lights (two small screws.)
slid door panel upward.
after than unplug the wiring...there you GO! you took off your door panel!
do me a favor and take pics of the whole proces...
i need to see what i have to do to keep my darn mirror from wiggling when im driving..
oh yeah and for those who want the suicide kit...dont get it from andy's autosport...they're jerks.
Old Dec 9, 2005 | 08:49 PM
Ok thanx, will do that on sunday. It's the only day I have off this week, I'll take pix too!
Old Dec 11, 2005 | 09:24 AM
Fixed my mirror!
I didn't take any pictures but the process is very easy...
Pop the inside door handle housing off first
the three screws mentioned above
there are four plastic prongs to pop... one above the speaker, one above the step light... one about 9 inches above that... and one about 4 inches below the mirror...
to tighten your mirror there is enough slack in the wires for the step light and power door/window controls that you don't have to disconnect them to access the mirror
there is one 10mm/phillips head screw/bolt at the bottom of the triangular mirror cover and 2 plastic prongs then the 3 10mm/phillips head screw/bolts are right in your face
any ?'s post a reply
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
BobTX10
Oct 7, 2015 08:43 AM
