FSTB on 99
FSTB on 99
Is there a way to get a strut bar on a 99 without cutting off the metal bracket thing on the tower? I was looking at the bar on the q45 and it's only bolted down by two of the strut bolts (same thing on camrys), so is there one like this for our cars, because by not having to use the bolt on the front i wouldnt have to cut anything...Also, getting totally off my own topic, which brand of coils for 99s is the one that doesnt have the problem b/c i think i have a misfire and im gonna swap mine out. thanks.
ok well i dont know how to post a pic so it shows up but here's a link...
http://memimage.cardomain.net/member...161_5_full.jpg
that bracket i circled (kinda hard to see) seems like it would definetly get in the way
of a strut bar. i think the bracket may only be on 99s but i dont know for sure. thanks for your help.
ok so there's no way get one on without cutting it off then? if anyone's seen a bar that is only held down by two of the bolts (like what i was talking about on the q45) please tell me because i want to get one but dont know how i'd feel about cutting metal under the hood.
Thanks Shock
...Same generation or not though...from his picture, that's the bracket I cut off of the 2000 to get the FSTB collar onto that side. (Maybe his manufacturing date was late enough that someting like that was incorporated into his 99?)
Anyway, it was simple to do and although I couldn't figure out what the heck that bracket was for (Maxima uses it?) I know it wasn't there for structural reasons, ...so off it went.
A couple of minutes with a Dremel cutting wheel and afterwards, some touch up paint and it looked perfectly normal.
I can't promise that the Stillen will have a (skinnier?) collar and not also require a cut, but again, it's a simple "adjustment" all the same.
Yeah...that aluminum tube is part of your a/c system. Some FSTBs mount up very close to this tube while others require some adjustments. Be careful if you do need to adjust it though. Go slow. I would imagine that many of them are close enought that they may touch or knock together while driving, no matter who makes it.
I had this happen and thought I had a wheel coming off it was so loud. A little adjustment and some black foam insulation around the A/C tube and all is fine now.
I own a '98 I30, and I had a problem with my FSTB hitting the top of the metal, high pressure hose from my A/C unit.
What I did was to put washers under the bolts closest to the bar to raise the bar up enough to clear the hose. I also rested the left bracket on top of the metal hose support (see photos: Full shot of FSTB ,Shot of FSTB bracket resting on A/C hose bracket )
Nismo87SE
Nov 1, 2000 06:11 PM
