2001 I30 with P0420 DTC
Old Feb 25, 2005 | 05:52 AM
ramakie's Avatar
I have a P0420 DTC (Catalyst Efficiency Below Threshold Bank 1). Is this most likely the O2 sensor or something of a greater problem? Any help would be greatly appreciated. Thanks
Old Feb 25, 2005 | 01:12 PM
attomica
I actually had the same issue just two weeks. I went to Autozone to get the code pulled (they do that for free) and they cleared the code while I was there. It has not yet re-illuminated.
If you look at the Fifth Gen. stickies, there's a thread entitled "GOT Check Engine Light?!? WHAT should you do?". Click that thread and you'll find a link to some FAQs. This specific code is covered in there somewhere. I don't remember where exactly, but some searching will show it.
What is said is that this code is the result of tolerances in the ECU that are set too close. Typical corrective action is taking it to the dealer so they can re-flash the ECU. It is a thirty-minute job and should cost nothing because there a TSB issued for this and it deals with a component of the emissions system, which is covered under warranty until 8/80,000.
user 11122324
42
Jul 18, 2022 03:35 PM
AaronL
Aug 8, 2020 10:31 AM
uttadms31
Sep 30, 2015 05:24 AM
Tmax78
Sep 25, 2015 09:07 PM
