Knock Sensor Tightness
Old Apr 26, 2005 | 05:25 PM
SuBXeRo's Avatar
Ok its supposed to be 20-25 lbft torque, but i did it the bloody hands way,a dn well quite frankly its bit hard to get an accurate torque rating like that. I tightened it once and then a bit more. My question is what happens if its not tight enough? too much makes it more senstive, i know that, so this would make it less sensitive?
Old Apr 27, 2005 | 11:24 AM
i30ds's Avatar
Armed and Dangerous
well, you wanna make sure that it is on there decent. If the factory torque spec is only 20-25 then that is not that tight. You could eaisly achive that with just a box end wrench by hand. Just keep working on it. You will enventually get it on there tight. Try removing the air intake all the way up to the throttle body so you can get enough room to get in there.
Old Apr 27, 2005 | 02:11 PM
SuBXeRo's Avatar
for me the intake wasnt int he way, i put a paradox systems one on, its justthe wires next to the heads that prevent any good movement
Old Apr 27, 2005 | 05:50 PM
RA030726's Avatar
I'm nutty for Nissans
just tighten it down good and snug. it will work fine as long as its not lose.
Old Apr 28, 2005 | 03:31 PM
SuBXeRo's Avatar
Old May 4, 2005 | 03:15 PM
LockNTross's Avatar
I don’t know either, why don’t you tell us? Specifically I want to know how's your gas mileage.
I have read a few threads on this before; the Knock Sensor is supposed to help gas mileage. However I haven’t seen any reports by members stating how much it helped them. Would you mind posting your results?
Old May 4, 2005 | 09:13 PM
i30ds's Avatar
Armed and Dangerous
When I replaced my KS along with all 3 o2 sensors, my gas milage increased from 17 MPG to 22 MPG on a the same city/ highway combo...
Old May 6, 2005 | 08:31 AM
adly's Avatar
How much
I need to replace my knock sensor, speed sensor, and the EGR valve. How much should all of these things cost.
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
