Servicing da I30T
Old Apr 29, 2005 | 11:53 AM
rLx77's Avatar
Servicing da I30T
Hi all,
I have a 2001 Infiniti I30T. I purchased it at 34,800 miles last year. I do not know if the previous owner had done any service with the automatic transmission fluid, or the radiator/coolant flush. I will assume the previous ownder did not do those services. The car now has close to 50,000 miles. I don't push the car too hard typically, and drive 75% highway, 25% city. I live in NY, so we have 4 seasons a year. I change oil every 3,000, and rotate tires every 5,000. Other than that, I haven't put much service into the car (did change struts, add new wheels/tires, but those are more "modding").
Question: Do/Should I be concerned about servicing the ATF? I want to prevent problems with the engine in the future. If you guys think I should, I'll probably bring it in tomorrow morning to get the ATF changed/flushed/serviced (whatever it needs, I'm clueless about ATF stuff). Also how about the coolant? What other things should I be servicing at around 50,000 miles?
Old Apr 29, 2005 | 12:06 PM
attomica
I waited until the 60K interval to service my ATF. I belive that's the interval recommended by the I30 manual. I had the engine coolant flushed and filled at the same time.
Old Apr 29, 2005 | 12:13 PM
i30ds's Avatar
Armed and Dangerous
ATF/MT oil- 30k
Coolant- 30k
Air filter- 15k
fuel filter- 30k
spark plugs-30k
PSF-30k
Brake Fluid-30k
Clutch Fluid-30k
Oil-3k
Now of course most people go double these amounts before replacement, but that is suicide...
Old May 4, 2005 | 07:41 AM
PhillyDonut's Avatar
Originally Posted by i30ds
ATF/MT oil- 30k
Coolant- 30k
Air filter- 15k
fuel filter- 30k
spark plugs-30k
PSF-30k
Brake Fluid-30k
Clutch Fluid-30k
Oil-3k
PSF-30k
Brake Fluid-30k
Clutch Fluid-30k
Is it necessary to change these at 30K interval?
Old May 4, 2005 | 04:52 PM
NOCturnalI30's Avatar
i got 85000 and bought it with 71000 what should i do about the atf should i flush it or drain and fill it and with wat????
Old May 4, 2005 | 05:23 PM
this thread has all your needs
http://forums.maxima.org/showthread.php?t=149056
Old May 4, 2005 | 09:17 PM
i30ds's Avatar
Armed and Dangerous
Originally Posted by PhillyDonut
PSF-30k
Brake Fluid-30k
Clutch Fluid-30k
YES... Or you could be like the average man and run it to 100K... while you are at it, might as well run the engine oil to 15K... what the hell ya know, it is just a car...
my03maxima
Jul 28, 2024 07:40 AM
Excalibur23
Oct 13, 2015 04:33 PM
RealityCheck
Oct 2, 2015 06:34 PM
The Wizard
24
Oct 1, 2015 08:47 PM
Max8
Sep 22, 2015 02:53 PM
