cloudy/scratched cover over instrument panel
Old Jun 8, 2005 | 07:32 PM
sascuderi's Avatar
Anyone have a solution to a scratched up plastic cover over the instrument panel on a 2000 I30?
Any products that will shine it up clear and transparent??
(don't want to buy a new one!)
Old Jun 8, 2005 | 08:06 PM
karguy's Avatar
Meguiars makes a polish/cleaner for about $6.00 plus shipping. Worked great on my I30. Website is www.meguiars.com They make great stuff!
Old Jun 8, 2005 | 08:23 PM
spacedout's Avatar
might be too extreme, but if its bad you can always wet sand and buff it.
Old Jun 12, 2005 | 02:46 PM
sascuderi's Avatar
I ended up using Mother's plastic polish/cleaner with so-so results. (parts still have a haze over the plastic) It may just be time to replace the cover. Anyone do it and do they sell just the cover? Cost?
Old Jun 12, 2005 | 04:40 PM
CreativeDesignz's Avatar
cover is liek 26 bux from the dealership i think. use rubbing compound then the polish...it should come out perfect
Old Jun 12, 2005 | 06:22 PM
Dr.Monkey1313's Avatar
I purchased a new one fromt he dealer a few years ago because of the same issue and if I remember correctly, it was only about $10 for the plastic lense over the guage cluster. That is just for the clear plastic piece. May be worth it and save you time.
Old Jun 13, 2005 | 06:13 PM
sascuderi's Avatar
Thanks for the input!
Old Jun 14, 2005 | 10:43 AM
i30ds's Avatar
Armed and Dangerous
I used some of my Mother's **** called "back to black" on the rear window seal... it only lasted 2 days before fading again.
Old Jun 14, 2005 | 06:53 PM
sascuderi's Avatar
Well this is what I did and it worked great. Instead of getting a new one, I used the mothers plastic polish as noted above. Still had lots of scratches and areas that were cloudy.
Then I noticed that as I cleaned off the plastic cover with a damp cloth, the plastic was clear when wet. So I thought, what can I use to keep the cover wet?
So, I sprayed the cover with CRC 2-26 Plastic Safe Lubricant. (From Home Depot. The stuff seals electrical connections) The stuff dries crystal clear and hides all the scratches!!!! When I should it to my wife she said "what did you do, take the plastic cover off?" Thats how transparent the cover looks now!
So if you want a quick fix to cover all the scratches on your plastic instrument cover, just spray it with CRC 2-26!
Old Jun 14, 2005 | 09:01 PM
or u could have clear coated it
Old Jun 6, 2011 | 01:37 PM
Limited Editon 04's Avatar
elimintate scratches in two minutes.
Before you spend hours on this try my way.......which I leaned the hard way.
Use the shiniest silicone protectant, I like Black Magic myself. Wipe plastic with a damp cloth slightly impregnated with a drop of dishwasher detergent. When dry get the softest cloth you have and just wipe some of the Black Magic on it -- lightest coat you can put on. Done! Like new, will last for around a year.
Old Jun 6, 2011 | 04:35 PM
tigersharkdude's Avatar
did you really just bump a 6 year old thread?
Old Jun 6, 2011 | 07:56 PM
pahanorlando's Avatar
lol. May be he's just trying to get his 15 posts
Old Jun 7, 2011 | 05:29 PM
sascuderi's Avatar
Thanks for answering my post from 6 years ago!
But what I ended up doing is replacing the tinted plastic cover with a new clear one from the max. This solved two problems...scratches are gone and I can see the guages again as the cluster lights in the I30 have dimmed with age.
mkaresh
Mar 12, 2018 06:48 PM
doctorpullit
Mar 29, 2016 11:08 AM
jonreidhead
Jan 6, 2016 09:38 AM
carid
Sep 17, 2015 05:00 AM
