Confounding grounding wires
Old Jun 8, 2005 | 08:13 PM
dr-rjp's Avatar
I recently purchased a grounding kit that came with six wires, a negative battery terminal adapter, and a round disk to which one end of each wire is to be connected.
While I was researching grounding kits, I found others that contained either five wires or four wires, and some of the five wire kits (like Stillen) had two wires joined at one end.
Well, I tried connecting my kit according to some instructions offered up by a Car Domain member, and when it came time to fire up the engine -- it didn't!
All I heard was, "Click!"
Needless to say, I removed the wires and returned the battery to its original state. Then I decided to follow the directions provided by Active Tuning for their four-wire grounding kit.
In less than 30 minutes, all four wires were connected, with only one wire going to the negative battery terminal. The car starts fine -- quicker than before -- but, other than that, nothing noticable in terms of performance.
Now, my question to the group is this:
Why all the variations here with the different number of wires AND the different connection sites?
I've got two wires left over, and despite the Active Tuning setup I used, I'm still wondering if there is a place under the hood for more connections. For example, I do not have a wire going to the transmission housing, and I'm thinking of running one to its existing grounding site.
My current connections are as follows:
1. (-) battery terminal to existing grounding site on frame below, and to the right of the fuse box on driver's side.
2. Cylinder head to existing grounding site on frame near filler tube for window washer.
3. Intake manifold to existing grounding site on frame near where #2 was attached.
4. Timing valve cover to frame under the cruise control servo vaccum.
Any thoughts?
Old Jun 11, 2005 | 01:01 PM
cefiro8701's Avatar
try putting them in different places...i heard you have to experiment with these things...
Old Jun 11, 2005 | 08:31 PM
dr-rjp's Avatar
I just finished an article in NissanPerformanceMag about a grounding kit that daisy-chained them; i.e., battery to chassis to manifold to transmission to cylinder head to timing belt cover, etc..
Old Jun 14, 2005 | 11:09 PM
HomerMAC's Avatar
Donating i30 Owner
well sometimes even if you think u tightened the nut on the negative terminal it still might not be tight... i learned this after wiring my heads with relays.... and realized that i didnt tighten.... when i tried to start car it did click thing...
Old Jun 15, 2005 | 03:20 PM
csnv's Avatar
Any thoughts?
It's supposed to give you smoother accelleration, better eletrical systems if you have some problem with them (who knows what kinda systems you put on your car or even stock), gear change much smoother, no jerky feeling.. basically.. better ground for all your electrical related stuff. More than 3 cables is a little over kill, but if it gives you peace of mind then do it.
Old Jun 15, 2005 | 08:39 PM
dr-rjp's Avatar
Which of the four I mentioned would you eliminate?
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
