G35 Brake Calipers
Old Jul 28, 2005 | 06:57 AM
SYCEFIRO's Avatar
G35 Brake Calipers
Would there be any advantage for G35 (non-brembo) Brake calipers over stock i30 brakes? Does anyone know the specs and if it'd be able to fit 96-99 i30's?
SY
sycefiro@yahoo.com
Old Jul 28, 2005 | 07:26 AM
Kevlo911's Avatar
Kevlo for President
I dont think they will fit, but I believe they are 2piston.
The upgrade I am doing is the J30 calipers, they fit and require minor modification of the rotor.
Old Jul 28, 2005 | 07:45 AM
BikTrash's Avatar
There are some added advantages like the 300zx brake swap. The front's bolts would have to be drilled and tapped to fit a 14mm if i remember correctly. The rest is the same as the maxima 300zx brake swap. Milling the rotor. I believe the 300zx would be cheaper and give you the same benefits (rotors and calipers ~ $200).
Old Jul 28, 2005 | 10:31 AM
Jeff92se's Avatar
I'm needing a caw
What are your constraints? The 2 piston caliper would be a decent upgrade if they bolt on. If you have the space a 300zx 4 piston caliper with the 13" cobra rotor would be alot better. But I believe the J30 (as mentioned) and the older Q45s have 2 piston iron calipers that have similar mounting dimensions as the 300zx 4-piston calipers. But without the big clearance requirements.
Old Jul 29, 2005 | 10:20 AM
sciff5's Avatar
How bout the Brembo G35 brakes? I would deffinatly like to put those on my I35. Is it possible?
Old Jul 29, 2005 | 10:48 AM
cefiro8701's Avatar
why not just get the brembos made for ur car?
Old Jul 29, 2005 | 11:02 AM
Kevlo911's Avatar
Kevlo for President
Apr 16, 2020 05:15 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
