2000 i30 question???
Old Sep 4, 2005 | 09:25 AM
edlab03's Avatar
hey whats up guys,
im having the "BRAKE" light and "BATTERY" light come on in the mornings when i first start the car. it stays on for about 2 minutes of driving then goes away.
i have a brand new battery installed and the brakes were checked out by my mechanic and he says there is absolutely nothing wrong with them.
anybody ever had this problem? any help would be appreciated.
thanks.
Old Sep 4, 2005 | 09:34 AM
99i30LIMITED's Avatar
Hey, i'm might be wrong, however i had a problem simular to this and my problem was the alternator or starter i can't recall. Goodluck!
Old Sep 4, 2005 | 12:44 PM
PerfectVQ I30's Avatar
ya, its most likely your alternator
i had an altima and 200sx do the same when the alternator went out, if it goes on and back off your alternator isnt 100% shot but it sure is on its way...
Old Sep 5, 2005 | 05:49 PM
edlab03's Avatar
well....
I just came back from a 80 mile trip and almost didnt make it home. my lights started flickering on and off (mind you its pitch black out here in Birmingham, Al.). I pulled into my parking spot and the car shut off, I had to push it the rest of the way. I'm going to get the battery checked out tomorrow and also the charging system. Hopefully its not the alternator and the battery is shot. If its the battery then I can grab the Optima Yellow top and throw that in. Hope thats going to work and its nothing major.
Old Sep 5, 2005 | 07:30 PM
Dude its your alternator, reason why your battery is shot is because you couldn't recharge it.
Old Sep 6, 2005 | 04:22 PM
edlab03's Avatar
thanks for your help.
the car started up right away this morning without any hesitation. the downside is that the "brake" and "battery" light are still on.
hope this doesnt turn out bad.
does anyone have an idea on how much replacing a alternator would be? how hard is it to replace? might be a nice DIY.
thanks again for your help.
-ed
Old Sep 6, 2005 | 06:08 PM
Tigger's Avatar
I had the same thing happen. Replaced the battery with a Yellow top and made it 4 days before it died again. Alternator was shot. 30K on the car.
Old Sep 6, 2005 | 07:07 PM
edlab03's Avatar
approximately how much did you guys spend on a new alternator? im trying to see what the ballpark figure would be.
Old Sep 6, 2005 | 08:16 PM
i30ds's Avatar
Armed and Dangerous
www.everythingnissan.com
Should not take more than an hour to do. Might as well change the belts while you are in there too.
Old Sep 6, 2005 | 09:05 PM
edlab03's Avatar
thanks for the link. i actually found that same one by searching around the org.
would there happen to be a "how to" floating around the org that anyone might know about? i would really appreciate it. thanks again guys.
Old Sep 6, 2005 | 10:32 PM
http://www.importec.com
http://catalog.eautopartscatalog.com...art=Alternator
ive order dozens of things from them, great equipment at great prices and you get to see what you order b4 you order it.
another option i use to use all the time is buy it from local pepboys or autozone and its llifetime warranty. Anytime the thing goes out free replacement. I went through 4 in 4 years with my altima i had and it was because i was overruning it with my system. With typical loads itll last well beyond 1 in 4 years....
as far as install goes here it is word for word from the FSM
it shows to remove from bottom of the car...
1. Remove Engine underover RH
2. Remove side inspection cover RH
3. Loosen belt idler pulley
4. Remove drive belt
5. Remove A/C compressor mounting bolts (four)
6. Slide A/C compressor foward
7. Disconnect alternator harness connector
8. Remove alternator upper bolt and lower bolt
Installation
To install, reverse the removal process.
i would send you the fsm pages but its kinda pointless as theres not really a picture of what to do. Ive never changed the alternator for an I30 or Max so i dunno if u "have" to follow all those steps but thats what the fsm says. Good luck to ya!
Old Sep 6, 2005 | 10:59 PM
i30ds's Avatar
Armed and Dangerous
www.motorvate.ca
Old Sep 24, 2005 | 09:50 AM
edlab03's Avatar
got quoted at $663 to replace the alternator and the belt. sounds a lil steep to me so i going to try around and see what other shops have to offer. from reading the link that i30ds provided, it seems like a pretty complicated job for your novice diy'er (me).
Old Sep 24, 2005 | 09:55 AM
663? You crazy the rebuilt alternator should not be anymore then 200 +/- plus belt's are maybe like 30-40 bucks. If you need help find alternator contact me PM
Old Sep 24, 2005 | 10:09 AM
edlab03's Avatar
thats exactly what i told the mechanic. ive seen a few rebuilts online for no more than $150-$175. he was charging me $400 just for the alternator and $30 for the belt. being sarcastic i asked him if it was brand new and he said well no that would cost more. i just simply walked out.
*birmingham sucks when it comes to auto repair. i moved down here about 3 months ago from queens, ny. damn i miss ny. would have cost no more than $300 for parts and labor. this place sucks! ! !*
Old Sep 28, 2005 | 01:34 PM
i30ds's Avatar
Armed and Dangerous
You could get a brand new oem nissan alternator for cheaper than that!
Old Sep 28, 2005 | 05:56 PM
edlab03's Avatar
i just wanted to thank you guys for all the help....
had it done today for $350 including parts, labor, the serpentine belt and the power steering belt. this is also with a lifetime warranty on all parts(alternator and belts).
not too bad if you ask me.
just wanted to say thanks again.
Old Sep 28, 2005 | 08:45 PM
i30ds's Avatar
Armed and Dangerous
Not to bad at all...
Old Oct 25, 2005 | 06:58 PM
Omar's Avatar
Installation
Wish I saw this when I changed mine. lol
Took me forever to figure it out.
The alternator cost me about $140. The labor was free since I did it myself.
Anyways, my car acted the same way as the original poster's I30 did. Mine had about 130K on the clock.
Mar 12, 2020 12:06 AM
RinconI30
Jun 11, 2016 08:25 PM
RinconI30
Nov 10, 2015 10:55 PM
ballerchris510
Sep 11, 2015 05:29 PM
