Door Chime
Old Sep 5, 2005 | 07:48 AM
Davis81387's Avatar
Door Chime
I had remote start installed on my car about a week ago and now my door won't chime when I put the key in the ignition and my headlight reminder doesn't work either. The installer said that they didn't do anything to the door chime module, yet it won't chime. What could be causing this problem?
Old Sep 5, 2005 | 08:14 PM
cefiro8701's Avatar
fuse??burned wiring??maybe they accidentally unplugged it?
Old Sep 5, 2005 | 09:10 PM
iRaMarine's Avatar
do the door and dome lights still come on when the door is open? If not, check the door switch.
Old Sep 5, 2005 | 09:37 PM
RA030726's Avatar
I'm nutty for Nissans
its mostly likely unplugged. pop off the knee panel and plug it in.
Old Sep 6, 2005 | 01:24 PM
Happy's Avatar
^^^ what he said little white plug u cant miss it
Old Sep 7, 2005 | 03:50 PM
Davis81387's Avatar
Yeah they do
Old Sep 7, 2005 | 04:01 PM
Davis81387's Avatar
Where is it actually located? I looked for it but since the remote start was installed there are a TON of wires down there lol it's like a jungle of wires. Can you tell me a more precise location? Everything that is down there seems to be plugged in though.....
Old Sep 8, 2005 | 10:02 PM
killerVQ30DE's Avatar
its on the plastic panel under the steering wheel.. not under the dash where all the wires are... remove panel below steering wheel.. there should be a connector attached
Old Sep 9, 2005 | 04:32 AM
Happy's Avatar
yea when u remove the panel thers a lil box there thats where the wire plugs into now ur installer was prolyl in a rush and pushed that wire up into the dash when he was stuffing all the others in so just look for it its a small 2 or 3 pin connector if i remember corectly
Old Sep 9, 2005 | 01:27 PM
clayman88's Avatar
Did you fix it yet? If not, I'd be having a word with the manager of the place that installed your remote start. They obviously jacked something up.
Old Sep 9, 2005 | 11:06 PM
Davis81387's Avatar
not yet, I've been working a lot lately but i'll try it sometime soon.
Old Sep 10, 2005 | 02:00 PM
roofadoofalus's Avatar
let us know what happens
Old Sep 17, 2005 | 05:12 PM
Davis81387's Avatar
I would just like to thank everyone for the help. The installer had unplugged it and thats why it wasn't working. I plugged it back in and everything is back to normal. I'm glad it wasn't a major problem because as forgetful as I am about turning my headlights off (during the daytime like if it's raining or something) I absolutely need it. I already had killed my battery once because of this and had to get a jump. Anyway, thanks everybody
REDinLV
Aug 15, 2024 12:30 AM
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
BobTX10
Oct 7, 2015 08:43 AM
