Ok so I want bigger Rotors, now what
Old Nov 11, 2005 | 10:02 AM
falconey's Avatar
I want bigger rotors, but I don't want to have to modify anything else, i.e. new calipers. I would prolly be willing to buy a new bracket, but I'm trying to do this w/o any modification to my braking system outside of the actual rotor itself. Now Meta I believe went with a complete 6th gen setup. Can I just use the rotor from the 6th gen set up or an aftermarket 6th gen rotor with my stock calipers or is there another rotor available that I can do this with?
As always thanks for the help.
Old Nov 11, 2005 | 10:44 AM
n3985's Avatar
大陆弟弟
http://www.mattblehm.com/
he offers a 6th rotor conversion without new caliper.
Old Nov 11, 2005 | 11:18 AM
NewLoveI30's Avatar
Just so know, you will probably have to get bigger wheels unless you already have at least 17's (not sure if stockers will clear the spokes).
Old Nov 11, 2005 | 12:49 PM
falconey's Avatar
Yeah I have 19's right now so that shouldn't be an issue.
Old Nov 11, 2005 | 05:46 PM
MetaOrbit's Avatar
Got Projectors?
If you have lots of clearance behind the spokes of your wheels, you have lots of options.
-There's a Wilwood 2-pc rotor + caliper kit available from I think precisionbrakes.com
-There's of course the $$$$ Brembo GT BBK
-Using the website n3985 referenced above you can use the 6th gen 12.6" rotor with 4 piston z32 300zx calipers
-Using the same website you can get a bracket so you can use the 6th gen 12.6" rotor with your stock calipers
-Or, if you have the clearance, you can do what I did and buy the 6th gen 12.6" rotors and the 6th gen calipers and mount those right up.
Apr 16, 2020 05:15 AM
captchaos
Mar 15, 2016 12:18 PM
Socalstillen
Sep 26, 2015 12:01 PM
jcvgn
Sep 10, 2015 08:03 PM
Maxboy23
Sep 4, 2015 06:04 PM
