Question about i30 Suspension...
Old Dec 17, 2005 | 04:45 PM
L0R1DA's Avatar
Does anyone have any detailed knowledge of the stock shocks/struts on the i30 vs. the i30t? I know the Touring edition has a "sports tuned suspension" but does that apply to anything other than the spring rate and rims? Do they have more durable struts? I'm asking because I have a non-touring sedan and I'm contemplating dropping it 1.5" in the front and rear with Ground Control Coilovers on stock struts and I want to assess the risk for decreased strut life expectancy. Thanks in advance.
Old Dec 17, 2005 | 07:51 PM
Tim96I30t's Avatar
Don't use drop springs on stock struts especially with coilovers, it will ride like shat. The T is just different wheels, option loaded, with stiffer spring rates. Buy spring and shock combo and if needed strut mounts and camber plates, do some research.
Old Dec 18, 2005 | 03:37 PM
i30ds's Avatar
Armed and Dangerous
The "sport" suspension on t is stiffer rear springs... everything else is the same. If you are thinking about dropping it on stock struts, think again... they will NOT hold up.
Old Dec 19, 2005 | 03:18 PM
L0R1DA's Avatar
Commonsense argees with you gentlemen, as do I. Guess I'm gonna sit on these Ground Control coilovers til I can afford a set of Tokico Illuminas...
Old Dec 20, 2005 | 07:50 AM
I30tMikeD's Avatar
agreed^
If all your looking for is a 1.5' drop and you would like to maintain a nice ride, then go with a quailty set of springs like Tokico or Tien combined with some Tokico Illuminas.
Old Dec 21, 2005 | 11:42 AM
L0R1DA's Avatar
Is there something wrong with Ground Control springs on Tokico struts? I have not seen anyone with this setup, but I got a pretty good deal on it, so I think I'm gonna go ahead and use them. Thoughts, opinions?
Old Dec 23, 2005 | 03:39 AM
phenryiv1's Avatar
Mod her. Ate her.
They ride really harsh, and if not tuned properly will ruin your handling. Much cheaper (amd better!) to sell them and get Tein H-tech springs and use Tokico Illumina struts, or to get a full Illumina Spring and Strut combo from the start.
Old Dec 24, 2005 | 01:28 PM
L0R1DA's Avatar
Interesting, wish I knew this before I purchased them. However, my current budget is stretched a bit thin for extensive car modifying so I do not think I will be selling the springs unless I find compelling evidence to. Anyone got experience with Ground Control/KYB AGX combo?
Old Dec 24, 2005 | 04:02 PM
phenryiv1's Avatar
Mod her. Ate her.
Yes. Even more harsh.
Old Dec 29, 2005 | 09:37 PM
L0R1DA's Avatar
Has anyone taken the cheap way out and just cut their springs to lower their ride? Come on, fess up! Let me know if I can get away with it until I save up for coilovers...
Old Dec 30, 2005 | 03:23 AM
phenryiv1's Avatar
Mod her. Ate her.
Yes, people have. Do not do it. If you read the 4th generation stickies, you would know that. Normally, that sort of nonsense is avoided in this part of the forum.
Why are you so stuck on coilovers? Buy what you want, but on NYC roads, you will hate how harsh coilovers ride. Get a mild spring (like H&R or Tein H-Techs) on a set of Tokico struts (either the Illuminas or HPs) and be done with it.
If you don't know that cutting springs is bad, then you have NO business trying to set and tune coilovers.
Old Dec 30, 2005 | 11:55 AM
i30ds's Avatar
Armed and Dangerous
Originally Posted by phenryiv1
....If you read the 4th generation stickies, you would know that. Normally, that sort of nonsense is avoided in this part of the forum...
...If you don't know that cutting springs is bad, then you have NO business trying to set and tune coilovers.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
uttadms31
Sep 30, 2015 05:24 AM
Socalstillen
Sep 26, 2015 12:01 PM
