Those with 18X8 rims
Old Feb 6, 2006 | 07:07 PM
NOCturnalI30's Avatar
I just got 18X8 inch rims, what size tires u guys running. I have a 2000 i30 so wanted some feedback on what u guys got on ur cars
Old Feb 7, 2006 | 09:07 AM
I30 Boogie's Avatar
I have 18x8 Evo's (HP)...I will double check the tire size but I know they are 40 series ....and (I believe) 245...but I will take a look tonight and let you know for sure.
Old Feb 7, 2006 | 09:17 AM
MetaOrbit's Avatar
Got Projectors?
You could do 235/40/18 or 245/40/18. I would go with 245/40/18. More sidewall, little wider.
Old Feb 7, 2006 | 03:22 PM
ershi30's Avatar
I had 245/40/18 on mine. Ride pretty good on these NY streets.
Old Feb 7, 2006 | 05:52 PM
Did ur tires rub on the inside of ur front wheel well when u turn. Cuz thats what happend when i borrowed my friends 6th gen rims. They rubbed like heck when i did sharp turns
Old Feb 7, 2006 | 05:55 PM
MetaOrbit's Avatar
Got Projectors?
Did he have the OEM 6th gen tires on it? If so, those are 245/45/18 and those are way too big.
Old Feb 7, 2006 | 06:14 PM
OK Kool i think thats wat he did have. If u gots no problem i love u man!!!
Old Feb 7, 2006 | 06:16 PM
MetaOrbit's Avatar
Got Projectors?
I don't have 18s, but a significant number of folks around here who do run 245/40/18 with no problems at all. And there shouldn't be. The diameter damn near identical to stock.
Old Feb 7, 2006 | 06:18 PM
falconey's Avatar
he prolly had the wrong offset wheels for the car.
Old Feb 7, 2006 | 06:22 PM
MetaOrbit's Avatar
Got Projectors?
No, he had 245/45/18 tires. That was the problem. 6th gen wheels' offset is fine.
Old Feb 8, 2006 | 12:53 PM
AlexI30's Avatar
I have 18 x 7.5" wheels, are you guys saying that a 235/45/18 will rub on a 4th gen too?
Old Feb 8, 2006 | 01:05 PM
MetaOrbit's Avatar
Got Projectors?
Since when were we talking about A32s? He has an A33.
I have no idea on the clearance on an A32. You'd be better served on a question like that in the 4th gen forum.
Also take note, OFFSET will play a role in any wheel+tire combination and whether it will rub.
Old Feb 8, 2006 | 01:17 PM
AlexI30's Avatar
Just figured someone might know, after all, this is a forum for all I30/I35s, not just the 5th gens, and the title of this post mentioned nothing about which generation we were dealing with.
Old Feb 8, 2006 | 02:13 PM
ImmaSquashYou's Avatar
it should not rub. i don't think 235/45/18 would be a problem, but i do'nt see why it would. i kon that 235/40/18 is fine...225/45/18 is fine, 245/40/18 is fine. 245/45/18 is a no no. 215/40/18 n ur asking for trouble. But i would say that 235/45/18 would be ok. I"m like 90% sure
Old Feb 8, 2006 | 03:28 PM
falconey's Avatar
My bad i thought he said he drove a sixth gen; guess i need to read better.
Old Feb 9, 2006 | 05:52 AM
AlexI30's Avatar
thanks for the info ImmaSquashYou
Old Feb 20, 2006 | 03:05 PM
Since i finally know what size to get now what tire should i get???
I personnaly wanna get the Hankook 405s buts just wanted to know what you guys had on your cars
Old Feb 22, 2006 | 10:09 AM
sergey85's Avatar
would 20x9 fit on an 98 i30
Old Feb 22, 2006 | 03:49 PM
it depends on what kinda budget your on. I personally wouldn't go with hankooks, just don't like them. Seeing that your in canada, i'm guessing you have pretty good snow tires n won't really have to worry about getting all season. Here's a list of good tires. Kuhmo 712, toyo proxes 4, continental extreme contact (great for snow, rain, n dry). If you don't wanna spend a lot, i guess you can get falken ziex 512, they're pretty good. Just look at the treadwear, u usually want to get around 300AA, that is usually around 30,000 miles. 220 treadwear is like 22,000 miles. Nitto 55 is a good tire but has wear of only 220, thats one reason why i won't get them
yes, but depends on the tire size. But i can tell you that you're most likely going to dent the rim before you can show it off to anyone. One pothole n BAM. there it goes!!!!
Old Feb 22, 2006 | 03:50 PM
yes, but depends on the tire size. But i can tell you that you're most likely going to dent the rim before you can show it off to anyone. One pothole n BAM. there it goes!!!! also you most likely have to get spacers n i don't think that yo u can be lowered
Old Feb 22, 2006 | 10:52 PM
sergey85's Avatar
would 8.5 would be good hen
Old Feb 23, 2006 | 03:00 PM
if ur using 20 in for daily driver, i wouldn't recommend it. 20 x 8.5 is better, but ur really asking for trouble. The biggest i'd ever go with are 19's. I currently have 18's n i think that it is big enough. Tires get a lot more expensive are u go up in rim size. If you really want to shell out like $75 everytime u hit a pot hole cause u just dented ur rim, then go for it. I was skiing in killington, vt, hit a pothole n had to drive from vt to boston, n from boston back to jersey. Over 500 miles on a donut is NOT fun....although i didn't care n still drove over 65 mph on them..-= )
Old Feb 27, 2006 | 05:56 PM
One last question and this thread can be closed forever. If i get 245 will it make my 18z look like 17z????? i hurd the more meet on the tires the smaller they will look is that true??
Metra i know u have an answer for meeeeee
Old Feb 27, 2006 | 06:07 PM
MetaOrbit's Avatar
Got Projectors?
True, the thicker the sidewall the smaller the wheel will look, but I think the difference between 235/40/18 and 245/40/18 will be neglible. If you're wondering, find some pics of Lee's car. If I recall correctly he's running 245/40/18 and they look just fine. And his wheels even have a lip (wheels with a lip usually look 1 inch smaller).
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Luigi623
Sep 21, 2015 01:42 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
0m3nc0w
Sep 11, 2015 05:21 PM
