Heated Seat Switches
Old Mar 4, 2006 | 04:43 PM
jester7377's Avatar
I'm relitively new to the site but I love it, and i had a question that I was hoping you guys could help me out with. I have a 01 I30 with heated seats and I was wondering if the switches were suppose to light up when you turn the headlights on. I know they light up when you turn on the heated seats, the orange light but i was wondering if any other part of the switch was suppose to light up?
Old Mar 4, 2006 | 06:33 PM
Tim96I30t's Avatar
No only lights up when activated to top/bottom, one led bulb inside with an orange reflector. I took out the reflector and put blue leds in one set that I have in my I30, I put red in another set I have sitting around.
Old Mar 4, 2006 | 07:40 PM
jester7377's Avatar
thats a good idea i may do that ... thanks for your help
Old Mar 5, 2006 | 11:22 AM
i30ish's Avatar
what kind of an led bulb is in there?
Old Mar 6, 2006 | 10:46 AM
Tim96I30t's Avatar
Radio shack has everything, I just took mine apart, took out bulb from rubber holder to use for size comparison. Use a resistor on the positive side, and any led bulb close to that size. There is a great thread on this with pictures of the switch taken apart a few months ago, 1-4-06 Mendon 99 How to heated seat switch......don't know how to post it here for a link
Old Mar 7, 2006 | 08:43 AM
KRRZ350's Avatar
Quick question, because I think the dealer installed both switches in backwards since the pictures of the seats on them don't face the same direction as on my I30 (we paid $500 to have them add on the heated seats option and got jipped on the mirrors, I'm so mad at myself for that one)
Do you push forward on the button for high and backwards on the button for low? (yes, I'm aware that this is by far the dumbest question I've ever posted on the .org)
Old Mar 7, 2006 | 09:32 AM
Tim96I30t's Avatar
Two modes on my 96 I30 heated seats back and butt not sure about newer I30s, did you ever fix your exhaust that exploded? 500 for heated seats wow...and they didn't give you heated mirrors that stinks
Old Mar 17, 2006 | 12:11 PM
flthere's Avatar
Small question on the same topic. THe driver side switch broke and after 3 months that it broke, I replaced it with a switch that I bought. But the seat won't heat up. I was thinking maybe some fuse blew in the process. Can someone direct me to the location of the fuse or let me know how I can fix it to have the heated seats functional again ?
Thanks !!
Old Mar 17, 2006 | 08:23 PM
i30ish's Avatar
Well one sure way to find out is to sit on it and feel the difference. if you can't feel the difference, there are 2 bars on each side of the switch, the fatter one will be the higher temp. i hope i understood your description correctly. Pics would help if i got it wrong..
Old Mar 17, 2006 | 08:27 PM
i30ish's Avatar
Thanks !!
Fuse for seats is inside the car. Not sure the exact location on a 98, but on a 2000 it’s on the left side right below the mirror control under the dash. The cover is square and has a hole for the handle.
Old Apr 1, 2006 | 12:02 PM
flthere's Avatar
thank you ... the fuse was indeed blown and i replaced it ... passenger side switch is glowing indicating it's working now but the driver's side switch is not glowing and i guess it's not heating ... donno how to fix this one malfunctioning side ... any input on what n how to check if the heating element in the driver's seat is gone/working ?!?
thanks again
Old Apr 1, 2006 | 02:58 PM
i30ish's Avatar
if switch doesn’t glow it does not necessarily means that heater is not working. Since the fuse was blown there might have been a short in a switch, blowing the LED and therefore the fuse. (Did you spill anything on it?) Sit down on the seat and turn on the switch, sit there for a while, 10 minuts should be sufficient enough to notice the difference. If nothing works I would say get a new switch or take it apart and clean it up as i did. Good luck!
Old Apr 14, 2006 | 07:05 AM
flthere's Avatar
thanks i30ish ... the heater is working !!! but the light doesn't glow ...
anyone has a diy to change the bulb inside the switch ? thx !
Old Apr 14, 2006 | 07:06 AM
flthere's Avatar
did u find the link and how to post it Tim ?? thx
Old Apr 14, 2006 | 12:49 PM
i30ish's Avatar
just some info about that. I’ve been to 2 shacks but didn't find any color LEDs, so you probably better be off ordering online.
gavin68
Sep 18, 2021 12:36 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
