OMG!!! Where is that bolt underneath the headlight!!!????
Old Mar 23, 2006 | 02:58 PM
n3985's Avatar
大陆弟弟
For the life of me I can't find the hidden bolt underneath the headlight so I can remove it, can someone help? Is it underneath the low beam side? high beam side? by the turn signal?.....etc? Thanks
Old Mar 23, 2006 | 05:24 PM
NOCturnalI30's Avatar
Dude u have to go underneath ur car. Its behind the wheel well. and its a 10mm bolt use a opened end wrench and ull be able to get it out
Old Mar 23, 2006 | 05:45 PM
n3985's Avatar
大陆弟弟
I was underneath the car doing my HID fog install, but will take a closer look later. Thanks
Old Mar 23, 2006 | 07:52 PM
NewLoveI30's Avatar
That thing IS a real b!tch to find.
Use a flashlight and look for a white, plastic arm (same plastic as the headlamp) coming off the headlight (over by the turn lamp). A ratchet will make things easier, but once you've got things loose just use your fingers.
And as forewarning, when putting everything back together, dont crank down the bolts until you have all of them in. I guess thats a good guideline for any job, but just the same it will make that third one much harder to line up.
Old Mar 24, 2006 | 07:43 AM
leeI35's Avatar
G37S > I35 > UR Max
Fug that. Turn your wheel so you can see the splash guard. Pull the snaps, and unscrew the splash guard. Unscrew the side of the front bumper and push it down until you seed the bolt that is securing the headlight. Unscrew bolt and you are ok. I did not have to go under car to remove the headlight. Just make sure you have a long enough socket wrench. Repeat steps for the other side and your done. Took me about 15 mins to remove both headlights. I did this all while it was rainning outside and I was getting my lights cleared at Corey (redlinemax) house .
Old Mar 25, 2006 | 12:14 PM
n3985's Avatar
大陆弟弟
Thanks, will try those steps once it stops raining/snowing.
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
Noela
Sep 26, 2015 08:22 AM
