How to take out window switch panels?
Old Apr 9, 2006 | 05:12 PM
i30ish's Avatar
Does anyone know how to take out panels with window switches? I tried to do it with a flathead, with no result.
Old Apr 10, 2006 | 04:26 PM
MetaOrbit's Avatar
Got Projectors?
No idea, but I'd say take off the door panel and look at it from the backside. Probably be easier to figure it out from there.
Old Apr 10, 2006 | 06:51 PM
i30ish's Avatar
Well, taking off the door panel is what i'm trying to do. I unscrewed the 2 screws and took off the plastic from around the door handle (that opens the door). I tried to take off the panel by pushing it whichever way with no result, so i thought i had to take off the window controlls. Anyway, i guess i can take off the door panel without taking off the controls, wouyld you care to guide me how to take the door panel off?
Old Apr 10, 2006 | 06:59 PM
MetaOrbit's Avatar
Got Projectors?
The window switches do not need to be removed. You unplug them from the rear.
http://nicoclub.com/articles.php?id=157798
Old Apr 10, 2006 | 07:13 PM
NewLoveI30's Avatar
Did you remove the screw from the inside door pull? There is a little cap covering it... I think
Old Apr 10, 2006 | 07:14 PM
i30ish's Avatar
Thanks a mil! Just for info, my window glass is moving from side to side a bit when going up, so I'm trying to get inside the door to see what's up, and maybe tighten some screws...
yeah, there are only 2 screws in the door.
Old Apr 12, 2006 | 08:53 AM
Tim96I30t's Avatar
You have to take out the cup near the armrest as well, after everthing is off pull up and out.
Old Apr 12, 2006 | 09:59 AM
NewLoveI30's Avatar
I guess that screw in the doow pull is just in the back then. Sorry about that, It's been a while since I've removed the door panels.
Old Apr 12, 2006 | 12:48 PM
Dr.Monkey1313's Avatar
Correct me if I am wrong, but there is a screw in the door pull in ALL of the doors. I actually just took off all of my door panels this past weekend in order to replace all of the inside door handles with new chrome ones. If you need more detail on how to remove the door panels, let me know and I can put together a "how to" and email it to you, but I believe you need to do the following:
remove the two screws from the bottom of the door panel
remove the little plastic cover inside your door pull
remove that screw
now run your fingers along the edges of the door panle to pop the panle off the door frame
Carefully pull up and toward yourself, but do not jerk the panle off because there are wires attached to the door frame and the door panle that you need to unplug BEFORE you can pull the whole panle away from the door frame.
That should be all you need to do.
If you need pictures and a "how to" let me know.
Good luck
Old Apr 12, 2006 | 12:49 PM
LMAO. Before anyone else can make fun of that sentence in my last post, YES I did say do not jerk the panle off!!!!! LMAO
Old Apr 12, 2006 | 03:06 PM
brio_max's Avatar
Learning English...
http://surl.se/axiv
Old Apr 12, 2006 | 08:02 PM
i30ish's Avatar
ok thanks for the input, you can stop posting now, i got it off after MetaOrbit post.
Old Apr 12, 2006 | 08:20 PM
i30ds's Avatar
Armed and Dangerous
The posting will NOT stop... it never does!
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
Fbana41
Aug 29, 2016 12:18 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
