Folding LED mirrors installed..
Old May 4, 2007 | 07:15 PM
  #41
cprx7's Avatar
Old May 4, 2007 | 07:41 PM
  #42
MetaOrbit's Avatar
Got Projectors?
Originally Posted by cprx7
What I love most about the mirrors is the slanted edge that does away with the blind spot. All cars should come with mirrors like these.
I agree. They were weird to start with, but now they're incredible. It's hard to drive any other car with regular mirrors. It's nice not having to worry about blind spots.
Old Jun 4, 2007 | 10:49 PM
  #43
danger300z's Avatar
yo those mirrors look sick . is it worth the $ though?
Old Jun 5, 2007 | 07:41 AM
  #44
MetaOrbit's Avatar
Got Projectors?
Well worth it to me. I love the way they look. I hardly use the folding function, but I think the LED indicators on the sides (especially at night) are an invaluable safety feature and the blind spot areas built into the mirrors make my life a lot easier.
Old Dec 26, 2007 | 01:08 PM
  #45
n3985's Avatar
大陆弟弟
Jon, sorry to bump an old thread, ever find the dome wire to tap into?
Old Dec 26, 2007 | 02:02 PM
  #46
secondtonone317's Avatar
nycnissans
very nice........gotta get me some of these
Old Dec 26, 2007 | 05:34 PM
  #47
BLACKonBLACK98's Avatar
Former Vendor
nice, i got the ones from sy a long time ago, but haven't installed them yet. i don't see these on ebay anymore these days.
*edit* here they are. might have to sell mine...
Old Dec 30, 2007 | 12:11 PM
  #48
MetaOrbit's Avatar
Got Projectors?
LOL, I never got around to it. I think there's a pinout location at the BCM that could be tapped, but that made me nervous.
I tried tapping at the door-pin switch, but that didn't work either.
When I actually get time to mess around with the car again I plan to try tapping the power that lights up the "ring of light" around the ignition key. That lights up with the dome light as well, and might be easier to get to.
Old Dec 30, 2007 | 12:14 PM
  #49
n3985's Avatar
大陆弟弟
Ya, I am just looking a wire to tap into for the signal at least. Then I'll just run a relay to draw power from the battery, but need to find that damn signal wire
Old Dec 30, 2007 | 12:21 PM
  #50
MetaOrbit's Avatar
Got Projectors?
I just said F it and ran the wires into the engine bay and tapped the power for the turn signals right before the turn signal bulbs in the headlights.
And there's really no need for a relay. Those LEDs use such little power you can just tap straight from the stock wiring.
Old Dec 30, 2007 | 12:23 PM
  #51
n3985's Avatar
大陆弟弟
No no, I have other uses for that signal wire
Not only the LEDs on the mirrors, but also LED puddle lights in the side skirts, and maybe even CCFLs for the footwells. It'd be nice to have all come on with the dome light when I hit unlock.
Old Dec 30, 2007 | 12:26 PM
  #52
MetaOrbit's Avatar
Got Projectors?
Oh, I misunderstood.
Yeah, it'd be really easy to tie it all into the courtesy light on the door, but I'm like you, I want the magic to happen when the unlock button is hit.
Old Dec 30, 2007 | 12:46 PM
  #53
n3985's Avatar
大陆弟弟
Well here's the page from the FSM, maybe you can find out which fuse it is.
Old Dec 30, 2007 | 01:08 PM
  #54
Former Vendor
you should be able to tap the dome light somewhere near the kick panel. its been so long since i've done any wiring on my max the details are fuzzy. best bet would be to ask in the i.c.e. section. i'm sure one of the installers there knows where to tap.
Old Dec 30, 2007 | 01:09 PM
  #55
n3985's Avatar
大陆弟弟
Well I figured I buy a fuse tap and put it where the dome light fuse is, that should work theoretically.
One of these:
http://www.accessafuse.com/access.htm
Old Dec 30, 2007 | 01:26 PM
  #56
MetaOrbit's Avatar
Got Projectors?
One of these:
Problem is that there's no fuse for the dome light in this car, or at least not one I could ever find.
And IIRC, the dome light is negative triggered. In that there's constant power running to it but the ground is switched to turn it on and off. It's been a long time since I was looking at the FSM though.
As for the diagram above, I think it's a pinout from the SECU that you need to tap (not the BCM like I said before). I have a printout with the right thing highlighted somewhere. I'll have to see if I can find it.
  #57
Former Vendor
never heard of those but it looks like it should work. only problem will be the wire all visible in the fuse box. if you can live with it, looks like a great option.
*edit* or what he said ^
Old Dec 30, 2007 | 01:27 PM
  #58
n3985's Avatar
大陆弟弟
We do have a "room lamp" fuse which is a 5A fuse IIRC. Once taken out the dome would not work. But if it is negative triggered then it's going to be a problem.
Old Dec 30, 2007 | 01:35 PM
  #59
MetaOrbit's Avatar
Got Projectors?
Maybe that's what the problem was. My first inclination in tapping power (whether for better or for worse) is to tap straight from the fusebox. Now that you mention it, I seem to vaguely remember tapping it but that the puddle lights were constantly on (even when the car was off). That would lend credence to the negative triggered theory (which I swear I read in the FSM).
But again, I'm fuzzy on all this stuff; it's been a while since I looked at any of it.
The last thing I did to my car was to put the stock HU back in
Old Dec 30, 2007 | 01:36 PM
  #60
n3985's Avatar
大陆弟弟
Someone go find wire 31 in the SECU all our problems solved
Old Jan 26, 2009 | 01:11 AM
  #61
The Law's Avatar
I R The Law
Hey did anyone ever figure out the dome light issue? Cause I just ordered these and will be putting them on once I get them.
Old Jan 28, 2009 | 10:41 PM
  #62
Dome1's Avatar
Where can you get these mirrors?
Old Feb 2, 2009 | 02:04 PM
  #63
cprx7's Avatar
I never had the need to do this because my alarm was installed in such a way that it keeps the dome and L/R step lamps ON for 30 seconds when locking and unlocking. So, I just wired the puddle lights to the step lamps. Metaorbit is right though, the dome light is negative triggered through pin 31 on the SECU. Another source could be pin 30 (ignition keyhole illumination) but I am not sure how long that remains ON after lock/unlock.
So, if I were to do this I would get 12V from the step lamp connector in the door (pin 2 Red-Green color) which is always "hot" (12v) to the positive wire on the puddle light and run a ground from pin 31 or 30 on the SECU to the negative wire of the puddle light.
You should be able to get 12v triggers for the left and right turn signals from pin 5 (green-black) and pin 6 (green-yellow) respectively from the hazard switch. Ground can be done at any bolt within the door.
Of course, test the wires out with a multimeter first just to make sure.
Old Mar 14, 2009 | 10:35 AM
  #64
SurraTT's Avatar
HR Swap Pioneer
where from???
my car was vandalized, they broke both side mirrors off, so i think i might get these kind of replacements if have heated option.
Old May 31, 2009 | 05:56 PM
  #65
cwfalconfootbal's Avatar
Buyers beware, local pick up recommended. Slow to ship out items already paid for.
has anyone found out how to get the mirrors to fold 30 seconds after you have locked the doors?
Old Jun 16, 2009 | 10:46 PM
  #66
I35silversurfer's Avatar
I have Got to get me those
Old Jul 7, 2009 | 11:46 PM
  #67
firebirdsecret's Avatar
i love those mirrors man i cant find them anywhere, where did u get them?
Old Jul 15, 2009 | 08:30 AM
  #68
streetuner's Avatar
just go to www.thespeedline.com and it will link you to the eBay store that sells them...just go through the nissan tab on the left and browse through the items that come up
Old Jul 16, 2009 | 11:39 PM
  #69
RandallFlagg's Avatar
Wow thats awesome! Looks good!
Old Jul 17, 2009 | 04:07 PM
  #70
jrj2i's Avatar
nice
  #71
jrj2i's Avatar
sweet
Old Jul 24, 2009 | 10:50 AM
  #72
doggy style's Avatar
damn i like those a lot, i know the stock ones should fold but mine dont want to maybe because they havent been folded for a while. and how much did the led mirrors run for?
Old Jul 24, 2009 | 10:54 AM
  #73
98GleMax's Avatar
word that looks good mann
Old Aug 20, 2009 | 10:17 AM
  #74
Phantom-V's Avatar
How would i wire this up? i have the red/blk wire and a white/blk wire. where do these two wires go? just got them and i dont know where to wire them.
Old Aug 21, 2009 | 09:42 AM
  #75
vastmax's Avatar
^^ sell me your tein's and i will tell you exactly where to tap everything to get fully functioning TDM mirrors.
Old Aug 21, 2009 | 09:48 AM
  #76
SurraTT's Avatar
HR Swap Pioneer
mine came with a nice wiring diagram
Russ u got yours working??
do u fold them up much? i dont, i only do in a tight parking space
Old Aug 21, 2009 | 09:50 PM
  #77
vastmax's Avatar
folding is just for show, i just do it in car washes. Since mine are TDM, they have convex mirrors, puddle lights, heated, signals, and of course folding. I'll post up a diagram when i get a chance.
Old Aug 22, 2009 | 09:27 AM
  #78
n3985's Avatar
大陆弟弟
How did you wire the puddle lights?
Old Aug 22, 2009 | 12:06 PM
  #79
vastmax's Avatar
this may sound like a dik statement, but have you looked in the FSM? EVERYTHING you need to know to wire these up is in there.
Here's a hint, see what has common ground or a switched ground. Also, since i'm a nice guy, EVERYTHING except the folding function can be tapped in the SECU. That's all the help i'm going to give. I have the exact pins that you need to tap but since this thread has lasted ~2 years, you guys need to figure out how to read a wiring diagram.
Old Aug 22, 2009 | 03:10 PM
  #80
SurraTT's Avatar
HR Swap Pioneer
http://depoautolights.com/nissan-cef...e975a511d5d954
im not sure of the difference , but i ordered the cheaper ones
you can do many options
i didnt want the turn signals or puddle lights, so i just ordered power folding and heated, and the blind spot 2 pane lens
came with switch and all FTW
