100,000K mile service?
Old Sep 5, 2006 | 09:42 AM
99blkgle's Avatar
im back!
Aight, im about to rolover 100 thousand miles on my car i was wondering what all the stealers did for this service? And how much did you get charged? Also what all is inculded in the service, i want to know so i can do it my self, thanks
Old Sep 5, 2006 | 10:32 AM
alpinestars™'s Avatar
THIS IS...
Arm + Leg, then bend over.
Check your manual, It will tell you what is done.
Old Sep 5, 2006 | 03:03 PM
i30ds's Avatar
Armed and Dangerous
There is not really a 100K either since the intervals are every 30K (ie 90K). So, assuming that you have kept up your oil changes but everything else needs to be done, I would change:
tranny fluid
power steering fluid
brake fluid
spark plugs
fuel filter
air filter
coolant
Old Sep 6, 2006 | 08:46 AM
99blkgle's Avatar
im back!
lol, you ever changed a fuel filter on a newer i30? it aint on the wall, its in the tank, i just need to do it. i thought maybe they checked the valve lash and other things like that, Ive heard that you shouldnt change your tranny fluid after an 100k miles it will kill your tranny? Urban myth?
Old Sep 6, 2006 | 02:10 PM
kcryan's Avatar
Nope, not unless you havent changed it for the past 100k, change it defiently, cheap insurance
Old Sep 6, 2006 | 05:20 PM
i30ds's Avatar
Armed and Dangerous
Oh I thought you were 99... my bad. Eventhough its in the fuel tank, I'd still change it. All you have to do is remove the bottom part of the rear cushion to get to the access lid.
Yeah the tranny thing is true. I changed the tranny fluid on an old Ford w/ 95k that never had the tranny fluid flushed and the new fluid stripped the clutch packs apart which ruined the tranny. 1st gear was the only gear that worked. Its kind of a double edged sword... damned if you do and damned if you don't. Hopefully your tranny has been flushed at some point.
6spd4dsc
Mar 4, 2016 05:19 PM
markevans999
Oct 25, 2015 08:27 AM
fastcarny
Oct 6, 2015 10:42 AM
LtLeary
Sep 14, 2015 12:33 PM
