00+ I30t owners what size tires do you have ?
Old Sep 12, 2006 | 05:29 PM
00I30T420's Avatar
Im currently looking for some tires, and I wanted to get some input from any other 00+ Infiniti I30t owners and what size of tires they got of their I30t's.
Old Sep 12, 2006 | 06:06 PM
MetaOrbit's Avatar
Got Projectors?
If they're OEM 17x7 wheels then I'd go with sizes that are in spec.
i.e. 225/50/17, 215/55/17, 235/50/17
I run 225/50/17. Plenty of tire choices in that size nowadays.
Old Sep 13, 2006 | 02:00 AM
brio_max's Avatar
Learning English...
I've seen on Ebay Infiniti I35 with 225/55/17+stock rims and i couldn't believe these tyres are not rubbing, because the overall lenght is too big...
Old Sep 13, 2006 | 04:09 AM
MetaOrbit's Avatar
Got Projectors?
Yeah it doesn't make sense to use that size.
Old Sep 13, 2006 | 11:07 AM
The Flash's Avatar
Using stock size...works great
Old Sep 13, 2006 | 02:33 PM
00I30T420's Avatar
Whats the problem with 225/55/17+stock ?
If they dont rub I see absolutly no problem.
Old Sep 13, 2006 | 02:57 PM
MetaOrbit's Avatar
Got Projectors?
3.4% difference in speedometer and odometer readings would bother me. May not bother you, but it bothers me.
http://www.miata.net/garage/tirecalc.html
Play around with the different sizes with respect to the OEM size.
Old Sep 13, 2006 | 03:15 PM
brio_max's Avatar
Learning English...
That's the question. Do they rub or not, because i haven't seen anybody on the org running with such a high-diameter tyre.
I would be happy to know the answer, cuz i'm wondering to buy 225/60/16 tyres, which are almost "same" as 225/55/17...
You are right, but don't forget that the speedometer do not show the correct speed(shows less MPH) while driving with 215/55/16 tyres! It should be better with 225/50/17 and probably, 215/55/17 is the correct size for our speedometers.....
Old Sep 13, 2006 | 03:20 PM
MetaOrbit's Avatar
Got Projectors?
True, I'm of the belief that 215/55/17 is probably closest to accurate, but in light of the lack of explicit evidence supporting that claim I can only base any different size tire difference on that of the OEM size.
In any case, I believe that 225/55/17 is still on the upper end of the scale.
Old Sep 13, 2006 | 03:33 PM
00I30T420's Avatar
So aside from incorrect speedometor readings (which dont bother me one bit), should I be worried about anything else ?
Old Sep 13, 2006 | 03:40 PM
Dubzino's Avatar
If they fit with no rubbing I would go for it. My tires I have on mkae mine 5.4% too slow. it doesnt bother me just means my odometer is going higher as fast which in return is a good thing.
Old Sep 18, 2006 | 07:13 AM
mohiudr's Avatar
My 2000 i30t has 245/45/ZR17 tires. Planning to change my tires and wondering if I use the same size. They are a little rough in city driving. Looking for something more smoother ride. Your expert comments will help.
Old Sep 18, 2006 | 08:57 AM
MetaOrbit's Avatar
Got Projectors?
245/45/17 is too wide for stock 17x7 wheels.
Go back to 225/50/17, 235/50/17, or 215/55/17
The latter two should be more comfortable.
Old Sep 18, 2006 | 09:53 AM
mohiudr's Avatar
Thanks MetaOrbit for your quick response. One thing I realized is :
For vehicle stock tire size 225/50/17, Speedometer difference = 0% & Diameter difference = 0%.
For tire size 235/50/17, Speedometer difference = 1.552% too slow & Diameter difference = 1.53%.
For tire size 215/55/17, Speedometer difference = 1.783% too slow & Diameter difference = 1.75%.
For tire size 245/45/17 (my current tires), Speedometer difference = 0.658% too fast & Diameter difference = 0.66%.
Taking these differences taken into consideration, which tire would be the best.
Also which ones would be cheaper to replace with and what brand would you suggest.
Old Sep 18, 2006 | 10:16 AM
MetaOrbit's Avatar
Got Projectors?
You'll probably find the cheapest tires in the 225/50/17 range.
But if you want most comfortable then I'd go with 215/55/17 or 235/50/17 as they'll have more sidewall.
I've had good experience with Kumho Ecsta ASX and Toyo Proxes TPT in 225/50/17 myself.
Old Sep 18, 2006 | 10:29 AM
mohiudr's Avatar
Would you recommend all 4 tires to be same or is there an advantage in having different tires in front and rear.
Old Sep 18, 2006 | 12:01 PM
MetaOrbit's Avatar
Got Projectors?
All 4 the same.
Old Sep 18, 2006 | 03:04 PM
00I30T420's Avatar
Well I installed the 225/55/17 Goodyears on my car and the ride as smooth as if its brand spanking new.
The ride is smooth, quiet and very comfortable, and I am very very satisfied.
Old Sep 18, 2006 | 03:11 PM
RSG's Avatar
RSG
I wonder if 235/50/17 tires would increase fuel consumption over the 225/50/17 noticeably. (10% maybe?) Out of these, which one you prefer?
Toyo Proxes 4
Avon Tech M550 A/S
Yokohama AVID V4S
Old Sep 18, 2006 | 03:12 PM
MetaOrbit's Avatar
Got Projectors?
Toyo Proxes 4
Avon Tech M550 A/S
Yokohama AVID V4S
Couldn't say on the fuel consumption, though I doubt it'd be that noticeable.
Out of those three I'd probably choose the Toyo Proxes 4.
Old Sep 19, 2006 | 08:23 AM
mohiudr's Avatar
Wondering if 215/50R-17 Kumho Ecsta ASX BSW tires are a good choice for 2000 Infiniti i30t.
Old Sep 19, 2006 | 08:34 AM
mohiudr's Avatar
what model of Goodyears do you have
Old Sep 19, 2006 | 10:02 AM
MetaOrbit's Avatar
Got Projectors?
They're a little thin. Have something against 225/50?
Old Sep 19, 2006 | 03:33 PM
00I30T420's Avatar
Comforted Assurace or something like that, I got a very good deal on them (120 bucks each).
Old Oct 12, 2006 | 10:24 AM
mohiudr's Avatar
The tires are Pirelli 210 Snowsport 225/55/R17 97H. The rims are ASA AMG look-a like. This set is off an S Class Benz. Used for about 3000 miles. Owner willing to sell for $550.00.
Wondering if I can use them for my 2000 i30t and is the price right for these tires.
Old Oct 12, 2006 | 11:29 AM
MetaOrbit's Avatar
Got Projectors?
Well you likely won't be able to use the wheels if they're off an S-Class unless they were also drilled for 5x114.3 mm. Benzs use a different bolt pattern.
Old Oct 19, 2006 | 06:47 AM
mohiudr's Avatar
Hi folks,
I am wondering if P225-55R17 BFGoodrich Traction T/A Tires are good for my 2000 i30t. These are used tires with average 8-9/32nds. rubber (really don't know what it means).
Please tell me your experience with these tires and whats a reasonable price I should pay to get these.
Thanks again for all your help.
Mohiudr
Old Oct 19, 2006 | 08:04 AM
MetaOrbit's Avatar
Got Projectors?
Hi folks,
Mohiudr
4/32 is where tires should be replaced. You're not terribly far off on that.
The tire size has already been discussed in this thread. No need to go on that any further.
Check the Tire forum for reviews on that type of tire.
Reasonable price? Whatever you think is reasonable. I, personally, wouldn't pay very much at all for used tires.
Old Mar 8, 2011 | 09:31 PM
gulleyman's Avatar
Has anyone ever tried to run 235/55/17 or 215/65/17 on an I35? Mines an '03...wonder if they'd rub?
Old Apr 3, 2011 | 01:53 PM
beermonkey9417's Avatar
i got these ones:
there alot cleaner now
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
minsbang
Sep 11, 2015 08:48 PM
videomano
Sep 8, 2015 03:28 PM
jfl330
Sep 4, 2015 01:44 PM
