radio removal
Old Sep 20, 2006 | 08:06 AM
JMAXIMA's Avatar
radio removal
what are the basics to remove the headunit on an 03 i35- i don't want to start tearing into it and break a trim piece. thanks in advance.
-jon
Old Sep 25, 2006 | 06:30 PM
KI30t's Avatar
JMAXIMA, Seems like no one want to chime in so I guess I will. Hope this helps you out. Sorry for the delay.
Old Sep 26, 2006 | 12:37 PM
KINGMAX's Avatar
Hahaha, you drive the same car as mi madre. What color is it? Send me some pics. And why in the hell are you taking the head unit out????
Old Sep 26, 2006 | 01:09 PM
JMAXIMA's Avatar
r u back in raleigh? its silver with black interior. give me a ring the next time you are around.
Old Sep 26, 2006 | 03:36 PM
pimpsmatt's Avatar
just pop out the trim peice around the shifter with a screwdriver as indicated by letter d on ki30t's post. after that its pretty much self explanitory. one thing, DO NOT remove the wire harness from the ac unit, not sure why but i heard it was a big no-no
Old Sep 26, 2006 | 05:00 PM
KI30t's Avatar
pimpsmatt, If you are talking about the harness to the AC vents, it should not be a problem. It’s actually easier to get the vents out of the way to take the radio apart. If you are referring to the AC control unit below the radio, I disconnect my unit all the time to get the whole center console out as one piece. I have never had any problems when connecting it back, but there may be something that I don't know. If anyone else has thoughts on this, I would love to hear them. I'm just curious. Who told you that it was “a big no-no”?
Old Aug 31, 2007 | 03:01 PM
gdiddy's Avatar
Repost of images
Hey guys... I know this is an old thread, but could someone above please repost the image tutorial. Taking on this project next weekend and I want to know how hard it would be to do.
Old Aug 31, 2007 | 07:46 PM
MetaOrbit's Avatar
Got Projectors?
See if the images are posted in 5th gen or Audio forum. It's the same on the 5th gen max, basically.
Also, you should be able to find a post where the directions are spelled out in text if the images aren't anywhere. It's pretty straightforward though...pop out the trim around the shifter (flathead wrapped in cloth or trim wedge). Pull trim out, disconnect wiring harnesses behind it. Pop/wedge the vents out above the HU. I find it easiest to wedge the vents out of the dash from the sides until there's enough to grab on to and then yank them out (loud bang there, don't be alarmed). From there, remove two screws above the HU that hold the brackets in the dash and remove two screws below the HU that hold the brackets in the dash. Pull out entire center stack, remove wiring harnesses, do what you need to do, then reverse to reinstall.
gavin68
Sep 18, 2021 12:36 PM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
