Tire inflation on Max vs. I30
Old Sep 30, 2006 | 05:18 AM
dr-rjp's Avatar
I happened to notice in the 4th Gen thread that factory recommended inflation for Maxes is different for front vs. back, whereas I30's run the same all around.
Is that split recommended for all 4th Gen Maxes...or just the SE's (which have stiffer rear springs)?
If the split is recommended for all Max models, and the I30 is supposedly the same under the skin, they why is there a difference?
Old Sep 30, 2006 | 09:10 AM
i30ds's Avatar
Armed and Dangerous
Tire inflation is different between the front and back on the I30 as well.
Old Sep 30, 2006 | 03:52 PM
Dubzino's Avatar
Yea some punks at a tire shop really messed me up. They over inflated my tires to 50 psi and I didnt notice for a little and messed up my tire wear a bit. I have 225/35/20 rates tires. I normally had them set around 35 PSI I think it was. Is that right for 20's on our cars?
Old Sep 30, 2006 | 08:11 PM
i30ds's Avatar
Armed and Dangerous
You don't wan't to over inflate the tires. The max PSI is on the side wall. You better check it.
Old Oct 1, 2006 | 05:01 AM
dr-rjp's Avatar
Not on mine. The recommended pressure is 29 PSI front and back.
Old Oct 1, 2006 | 11:37 AM
i30ds's Avatar
Armed and Dangerous
Hmm... 97 label under the lid of the center console says 29 rear, 30 front. I would not look too much into small variances like 1 PSI.
The touring have totally different recommended inflation levels. 32 PSI or some thing if I remember correctly. Its not due to the stiffer 'sport' springs (if you even want to call them that), but due to the fact that they run larger tires than the non touring models.
Old Oct 2, 2006 | 06:21 AM
dr-rjp's Avatar
I'm running 215/60/15 (stock is 195/65/15), and 32 PSI seems to be the best all around inflation numbers.
Old Oct 2, 2006 | 12:42 PM
i30ds's Avatar
Armed and Dangerous
That is the size that the touring models run as well. So 32 PSI is perfect. I'm running 235/45/17 tires and I inflate them to 32 PSI all the way around. I've gotten pretty even tire wear at this level.
Old Oct 3, 2006 | 11:35 AM
Dubzino's Avatar
still confused
I have Nitto Neogen2 tires 225/35/20 and on them it says max tire pressure 40psi and in another spot it says 50psi. Any help would be great guys!
Old Oct 3, 2006 | 02:47 PM
i30ds's Avatar
Armed and Dangerous
Do all your tires match?
Old Oct 4, 2006 | 06:09 AM
dr-rjp's Avatar
If you're asking me, then the answer is "Yes. I just replaced all four about two months ago."
Old Oct 4, 2006 | 08:51 AM
i30ds's Avatar
Armed and Dangerous
No I was talking to the dubzino that says his tires have 2 different max inflation levels on them.
Old Oct 4, 2006 | 11:16 AM
Dubzino's Avatar
OK I got it now.Took a closer look today and seen the max while seating is 40 psi and the max tire preasure is 50 psi. So I should go 75% of 50 psi?
MR2 T'd
Jul 9, 2021 05:06 AM
captchaos
Mar 15, 2016 12:18 PM
MaxLife17
Sep 8, 2015 02:36 PM
jfl330
Sep 4, 2015 01:44 PM
